Posted: Fri Jun 19, 2009 12:23 pm Post subject: fuel pressure ? |
If I had a plugged/partly plugged injector, would my fuel pressure "twitch"?
I know the gauge should casually go up/down depending upon the load/rpm of the motor. _________________ 2008 GMC Z71
Posted: Fri Jun 19, 2009 12:31 pm Post subject: |
Needles aren't always rock steady on an analog gauge.
And no, clogs would actually register a higher pressure I would think.
Define twitch? _________________ A redline a day keeps the carbon away! |
Posted: Fri Jun 19, 2009 3:29 pm Post subject: |
I havent put the gauge on it yet. Was "thinking" maybe it would help diag the problem.
Twitch=wiggling really fast like a vac leak on a vac gauge. |
