'86 Z28 Parts Car - I may buy one. Do you need parts?
Goto page Previous  1, 2
PostPosted: Fri May 15, 2009 12:18 pm    Post subject: Reply with quote
I think you can solder a potentiometer or a different resistor in to make the V6 tach correct for the V8. Stock it wouldn't be correct at all.
I seem to recall finding that resistor on my car when I had the cluster out just to see where it was. Also, that's the procedure for fixing the later style dash tachs that have a habit of being hugely incorrect.
Still waiting for a call from him.
PostPosted: Fri May 15, 2009 12:23 pm    Post subject: Reply with quote
alloy wrote:
Quasi-Traction wrote:
Maybe the 140 speedometer. Not the cluster. Just the speedometer itself. Trip odo on mine doesn't work.
Not to hijack this thread, but the odometer problem is common and usually easy to fix. It's a broken plastic tab that allows the shaft to move up and the gears don't mesh.
Quoted for truth. My 145 had a broken trip-o-meter and I fixed it with some creative zip tie placement to pull it back onto the gears. It's obvious what to do when you get the cluster apart. Mine seems to be getting bad again though, I wonder if the other clip on mine is busted now? I hear welding wire is good for holding it down also.
91camaro_rs
PostPosted: Fri May 15, 2009 10:43 pm    Post subject: Reply with quote
i had to fix my tach by soldering resistors to the chip for the tach i think the resistance for the v6 is 265k ohms and for V8 195k ohms not quite sure tho, i have the numbers saved somewhere
PostPosted: Sat May 16, 2009 10:55 am    Post subject: Reply with quote
I've never heard of this. Can you dig up some more info?
d00012
PostPosted: Sat May 16, 2009 4:06 pm    Post subject: Reply with quote
How much would the engine cost? Computer and harness included?
PostPosted: Sun May 17, 2009 9:27 am    Post subject: Reply with quote
I just called again, for the third time, and finally got someone to answer the phone. The car is sold already to someone else. Rolling Eyes
I am still looking for a TPI parts car. Ignore the rest of this thread... Embarassed
91camaro_rs
PostPosted: Mon May 18, 2009 12:55 pm    Post subject: Reply with quote
yeah ill find the link for ya
PostPosted: Mon May 18, 2009 1:25 pm    Post subject: Reply with quote
Here you are sir.
http://www.thirdgen.org/techboard/electronics/357893-90-92-tachometer-fix.html
Give that a try. It's for 90-92 tachs, but the info is good for earlier ones also. Plus there's another thread specifically about the old ones somewhere on TGO also.
Page 2 of 2
