Yesterdays tech..
PostPosted: Thu Apr 30, 2009 6:36 pm    Post subject: Yesterdays tech.. Reply with quote
Today at work I had a 64 pontiac bonneville that I needed to pull the transmission and replace the torque convertor seal. No biggie right? LOL I learned a few things..
First, with the 4link rear on these old cars, they made the driveline very long. And when you rack one the rear end hangs down, shoving the driveline all the way into the transmission. There's no extra room to pull it out after removing the U-joint straps. I ended up having to set the car down on jackstands to get the rear up so the driveline would come out. Asked the boss when he got back about that, he said " oh ya.. i remember doing that"
Then, I get the transmission out, and go to pull the torque convertor. Yank on it.. it slides about 1/2" and clunk.. stops. Try prying a little bit.. huh.. this thing wont come out. So I ask paul, who asks the old timer in his shop. Says I need to take the ring gear bolts out(its attached to the torque convertor). I'm like wtf? I end up calling our transmission guy. He says same thing. Take those out, then the torque convertor will come apart. Theres a snap ring inside. HUH????
So I remove those bolts, and the convertor splits in 2.. weird.. here's a snap ring, remove another part. Then 2 more snap rings, now i'm down to a planetary gear.. inside the convertor? Remove that, and yet another snap ring, and finally the back shell of hte convertor comes out. Ah theres the seal! But of course I have the wrong one LOL. New one 2 days away and a weekend in the middle..
Here's a pic of this thing partway apart.
lostinconformiti
PostPosted: Thu Apr 30, 2009 8:19 pm    Post subject: Reply with quote
dude thats a PITA, just makes me glad me and buddy alex havent had to do that to his 66 catalina yet...
PostPosted: Thu Apr 30, 2009 8:29 pm    Post subject: Reply with quote
64 should have been the last year for that.
PostPosted: Thu Apr 30, 2009 8:38 pm    Post subject: Reply with quote
Even the old guy thought '64 was too new for that setup!
PostPosted: Fri May 01, 2009 12:26 am    Post subject: Reply with quote
lol. and people wonder why GM ended pontiac.
Razz
PostPosted: Fri May 01, 2009 6:32 am    Post subject: Reply with quote
Razz
Wasn't just a Pontiac thing. Old guy was actually suprised to hear it was in a Pontiac.
PostPosted: Fri May 01, 2009 6:33 am    Post subject: Reply with quote
Ya, that trans was designed by Olds/Cadillac. Pontiac is more responsible for the th400.
PostPosted: Fri May 01, 2009 6:34 am    Post subject: Reply with quote
And btw, that old auto is a 4spd. Not an overdrive though.
