help with engine codes.
lostinconformiti
PostPosted: Thu Apr 30, 2009 8:52 pm    Post subject: help with engine codes. Reply with quote
si there an easy wayto pull my casting number from the back of the engine because it seems like to me that its going to be a pita unless you guys and gals have a trick for me? im really only trying to find it because apparently my engine is a mutt and my suffix code doesnt show up anywhere its V0429FDW CF7179857 and my heads are stamped as 354434 which i hear are 75-79 smoggers. just trying to figure this beast out. anything helps as always.
PostPosted: Fri May 01, 2009 6:25 am    Post subject: Reply with quote
Use a mechanics mirror and a flashlight. Drivers side right behind the head. Usually not too tough unless you've got the smog pipe for the AIR system still there. Then you're f-ed.
PostPosted: Sat May 02, 2009 12:06 am    Post subject: Reply with quote
354434 are 60cc 305 heads from the mid 70's. Had the same ones on my old 350 before it blew.
