| what motor 327 or 350 |
| 327 |
20% |
[ 2 ] |
| 350 |
80% |
[ 8 ] |
| get another 305 |
0% |
[ 0 ] |
| Total Votes : 10 |
corey davidson Member
1986 Chevrolet Camaro
Posted: Sun Apr 19, 2009 11:42 pm Post subject: ok just in case i have to replace the heart fo hell beast |
should i go with the 327 or 350 id love ur guys vote for this i no they are both bad @$$ motor the 66 sting ray has a 327 in so idk what do u guys think _________________ real men are covered in oil and grease |
Posted: Sun Apr 19, 2009 11:46 pm Post subject: |
| which ever you can afford. |
Posted: Sun Apr 19, 2009 11:47 pm Post subject: |
none of them iv found a 327 and a 350 they both are around 150-200 _________________ real men are covered in oil and grease |
Posted: Sun Apr 19, 2009 11:52 pm Post subject: |
then maybe a little more information. What parts are included in each, what condition are they in, how much work do they need, etc.
You can make cool motors out of both of them, 327's have some really really great reasons to use it, but 350's certainly also have a lot of good points.
Honestly, considering the state of your car, I would get something that will actualy run, for more than a week.  |
Posted: Mon Apr 20, 2009 12:57 am Post subject: |
Corporate engines are your problem, you need a Poncho in a Firebird.  |
Posted: Mon Apr 20, 2009 6:28 am Post subject: |
$100-200 motor is going to land you in the same boat. _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 20, 2009 11:15 am Post subject: |
they both ran wen pulled so idk _________________ real men are covered in oil and grease |
GREG DAVIDSON Member
Posted: Mon Apr 20, 2009 11:39 am Post subject: |
i say the 305 thats in it cause i dont think it's blown but you just put some really bad jue jue on it. _________________
Posted: Mon Apr 20, 2009 2:00 pm Post subject: |
Whichever you can afford.
If you go to look at a new motor, rent a compression gauge/tester. Have someone rotate the balancer by hand, while you check the compression on each cylinder. I wouldn't settle for any motor with less than 120psi in each cylinder.
If they won't let you compression test it, I would pass on it. _________________
Posted: Mon Apr 20, 2009 2:39 pm Post subject: |
| Quasi-Traction wrote: | Whichever you can afford.
If they won't let you compression test it, I would pass on it. |
Didn't know you could rotate the motor by hand to reach proper ACCURATE pressure on a compression tester.
100PSI even is okay. What you're really looking for is consistancy between all the cylinders. Big cam, and you wont get as high a compression. _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 20, 2009 2:40 pm Post subject: |
well we just dropped her off at the shop that built the vette so we will see what happens _________________ real men are covered in oil and grease |
Posted: Mon Apr 20, 2009 3:33 pm Post subject: |
If you weren't so far I'd give you the 305 out of my bird... Needs valve seals but it did okay. _________________
Posted: Tue Apr 21, 2009 10:46 am Post subject: |
| iansane wrote: | | If you weren't so far I'd give you the 305 out of my bird... Needs valve seals but it did okay. |
you still have that thing?
I tried to convince derek (fiveoformula) that he ought to snag the LT1 cam outta that thing. _________________
fiveoformula Member
Posted: Tue Apr 21, 2009 11:16 am Post subject: |
| I would take that cam no problem, if he wanted to let it go (without the rest of the motor) but it would sit around a while until I get my tuning stuff and get good enough to tune for it.. |
Jason_Culbertson Member
1982 Pontiac Trans Am
Posted: Tue Apr 21, 2009 11:58 am Post subject: |
i love how no one voted for another 305  _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3 |
HAHA shoot, i'll take it off your hands tomorrow and have it installed this weekend... not the whole motor though. my garage is too full already. _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Tue Apr 21, 2009 9:09 pm Post subject: |
You didn't forget about me did you ian? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Apr 22, 2009 3:42 pm Post subject: |
| DBL_TKE wrote: | | You didn't forget about me did you ian? |
You and every other girl I've ever met....
Wait, wat?  |
Posted: Wed Apr 22, 2009 7:16 pm Post subject: |
| iansane wrote: | | DBL_TKE wrote: | | You didn't forget about me did you ian? |
Wait, wat?  |  _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Wed Apr 22, 2009 7:28 pm Post subject: |
Any word from the shop? _________________ A redline a day keeps the carbon away! |
