cameron7710 Member
Posted: Wed Apr 01, 2009 3:37 pm Post subject: window motor replacement cost |
just wondering if anyone knows around how much it should cost to get my window motor replaced at a shop cause m not going to touch it cause just searching on tgo shows me i dont wana risk my fingers or break my window but summers coming and i need to be able to roll the window down and pop off the t-tops. _________________
fiveoformula Member
Posted: Wed Apr 01, 2009 6:15 pm Post subject: |
That's a decent price for the motor. If you're going to have a shop do it, plan on a couple hours of labor. _________________ 92 Camaro
popballz Member
Posted: Wed Apr 01, 2009 6:19 pm Post subject: |
just do it yourself!, its really not that hard at all,
i had to take all the power stuff out of my new door and put my manual stuff in, it was not hard, just takes time and patience!  _________________ -Donald
Posted: Thu Apr 02, 2009 1:29 am Post subject: |
Do it yourself. At least you'll learn something. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
flea Member
Posted: Thu Apr 02, 2009 9:57 am Post subject: |
| I was quoted 800 for one window motor and solenoid from a dealership for a pontiac transport van. picked up the parts for 40.00 and had it done myself in a few hours time. So unless the dealership I went to was just WAAAYY outa line you really are better off doing it yourself. Unless you just want to spent a small fortune to have it done. |
Posted: Fri Apr 03, 2009 4:57 pm Post subject: |
| flea wrote: | | I was quoted 800 for one window motor and solenoid from a dealership for a pontiac transport van. picked up the parts for 40.00 and had it done myself in a few hours time. So unless the dealership I went to was just WAAAYY outa line you really are better off doing it yourself. Unless you just want to spent a small fortune to have it done. |
That transport vancould've had one of those units that the entire inside of the door needs to be replaced. Lock solenoids, motor, regulator, rods, cables, latch, everything.
Was the parts and labor or just parts? |
Posted: Fri Apr 03, 2009 4:58 pm Post subject: |
The dorman/cardone motors I've used have all been subpar IMO. I picked up a pair of siemens motors from Schmucks and they are smooth and quiet. _________________
mc6811 Member
Joined: 21 Feb 2009 Posts: 148 Location: Centralia, WA
Posted: Sat Apr 04, 2009 11:21 pm Post subject: |
Find a motor and let these guys walk you through it if any problems. I paid a shop 150 just for labor on a replacement window motor and all they had to do was drill a hole in the door panel to access the bolts. Felt kinda used.
 _________________ 12th Man Seahawk Fan |
flea Member
Posted: Sun Apr 05, 2009 6:35 am Post subject: |
| iansane wrote: | | flea wrote: | | I was quoted 800 for one window motor and solenoid from a dealership for a pontiac transport van. picked up the parts for 40.00 and had it done myself in a few hours time. So unless the dealership I went to was just WAAAYY outa line you really are better off doing it yourself. Unless you just want to spent a small fortune to have it done. |
It was parts and labor. only the motor and solenoid and regulator.
But this is all i needed
I backed slowly towards the door when they told me 800 bucks to install a 35 dollar part. |
