quick tire questions
91camaro_rs
PostPosted: Fri Mar 06, 2009 1:35 pm    Post subject: quick tire questions Reply with quote
ok so i am gonna buy some tires here soon so will 245/45/17's all around fit without rubbing when i turn?
and whats the biggest tire i can put in the back? would 255's fit?
PostPosted: Fri Mar 06, 2009 1:47 pm    Post subject: Reply with quote
I ran 245/45R18's no problem. I'm sure you will be fine if you have stock offset wheels.
PostPosted: Fri Mar 06, 2009 2:11 pm    Post subject: Reply with quote
Yeah, what size wheels, and what offset. I run 255/45/17's, with no issues.
PostPosted: Fri Mar 06, 2009 3:40 pm    Post subject: Reply with quote
I have the same size you are looking at on both of my cars with no issues. 17X8, zero offset on the 92 and 17X8.5, 26mm offset for the 89
91camaro_rs
PostPosted: Fri Mar 06, 2009 4:21 pm    Post subject: Reply with quote
i have the 17" by 8" chrome iroc rims i want to do 245/45/17 in the front and 255/45/17 in the back...will that work with no offset problems or anything?
91camaro_rs
PostPosted: Fri Mar 06, 2009 4:36 pm    Post subject: Reply with quote
ahhh i got another question could i also run like a 255/55/17 in the back and make the tire a lil taller or what? would a 255/55/17b fit in the rear?
PostPosted: Fri Mar 06, 2009 4:55 pm    Post subject: Reply with quote
Depends on your brake upgrades too. I've got the 1LE hubs and my 245/50R16 rub the inner tire cover at full lock because the hubs push the wheels out farther.
91camaro_rs
PostPosted: Fri Mar 06, 2009 5:13 pm    Post subject: Reply with quote
all my brake stuff is stock
PostPosted: Fri Mar 06, 2009 5:43 pm    Post subject: Reply with quote
On an 8" wheel, I would probably just run 245. I have 8.5" wide wheels, and 255's are about the max i would run on my wheel, I think you would be better off with 245's on the 8" wheel.
91camaro_rs
PostPosted: Fri Mar 06, 2009 8:05 pm    Post subject: Reply with quote
alright cool ill just run 245/45/17's all around
i actually decided not to go with nitto...Kumho Ecsta ASX's are going on
thanks for all your help guys
