tranny coolers
corey davidson
1986 Chevrolet Camaro
PostPosted: Thu Feb 12, 2009 1:06 pm    Post subject: tranny coolers Reply with quote
ok so we got the motor in but forgot to put the tranny coolent lines back on Bashy Bashy is there a way we could do this with out having to drop the tranny again
PostPosted: Thu Feb 12, 2009 1:50 pm    Post subject: Reply with quote
Is this for a 'real' tranny cooler or the factory setup that runs coolant through the sandwich plate at the engine oil filter?
corey davidson
PostPosted: Thu Feb 12, 2009 1:51 pm    Post subject: Reply with quote
idk they are metal lines that came off my 700r4
corey davidson
PostPosted: Thu Feb 12, 2009 1:57 pm    Post subject: Reply with quote
yea run from the radater to the tranny pretty much by the oil filter
PostPosted: Thu Feb 12, 2009 2:16 pm    Post subject: Reply with quote
It's been awhile since I messed with a 700, but I seem to remember that the coolant lines were on a downward angle, and you could snag them without tilting the tranny down any.
As far as what Mike was saying though, unless you really like swapping transmissions, you need to invest in an auxiliary cooler.
corey davidson
PostPosted: Thu Feb 12, 2009 2:33 pm    Post subject: Reply with quote
ok thanks we are gonna try to run the lines and hopefull do a start up tonight
PostPosted: Thu Feb 12, 2009 4:46 pm    Post subject: Reply with quote
You don't have to pull the trans to do it. A good flare nut wrench will come in handy.
PostPosted: Thu Feb 12, 2009 4:53 pm    Post subject: Reply with quote
Replace it all with rubber line. Don't forget to flare the ends! I can't stand those hardlines anymore.
PostPosted: Thu Feb 12, 2009 5:22 pm    Post subject: Reply with quote
Rubber line has a nasty habit of melting, tearing, slicing, and generally leaking.
PostPosted: Thu Feb 12, 2009 5:24 pm    Post subject: Reply with quote
he's just being lazy and not wanting to try and put the lines back up Laughing i nay have to try myself
corey davidson
PostPosted: Thu Feb 12, 2009 5:45 pm    Post subject: Reply with quote
im sick thats y im lazy Laughing
PostPosted: Fri Feb 13, 2009 8:48 am    Post subject: Reply with quote
Meh. If you do as much as you can with the hardline and keep the rubber forward of the exhaust you'll be fine. Makes it so much easier.
PostPosted: Fri Feb 13, 2009 10:34 am    Post subject: Reply with quote
In my experience it is far easier to bend hardline into shape than it is to route and secure rubber lines so they stay out of the way. But whatever works, I guess. Shrug
PostPosted: Fri Feb 13, 2009 11:20 pm    Post subject: Reply with quote
ok this thing is just being a pain now if it doesnt get beat on to heavely would it be ok to block off the cooler lines for the trans ? i knnow how these 700R4s are
PostPosted: Sat Feb 14, 2009 10:06 am    Post subject: Reply with quote
NO NO NO NO NO NO
Tisk tisk
You MUST have a cooler or you'll burn up the trans real quick. Be patient and don't be afraid to bend the lines a little to get them to fit. If you're struggling with the end at the trans, remove the crossmember and lower the trans down some with a jack to give you better access.
PostPosted: Sat Feb 14, 2009 10:13 am    Post subject: Reply with quote
did that theres still no room dm i hate automatics
PostPosted: Sat Feb 14, 2009 10:47 am    Post subject: Reply with quote
It's no where near impossible. But sometimes they do fit you. It's also easier to unhook them from the radiator if they aren't already.
PostPosted: Sat Feb 14, 2009 10:49 am    Post subject: Reply with quote
yea got one in one to go if it was'nt for this trans this car would be down the road buy now Crying or Very sad
corey davidson
PostPosted: Sat Feb 14, 2009 11:01 am    Post subject: Reply with quote
dam autos Laughing
