Richster Magic Fingers
Posted: Wed Feb 11, 2009 11:18 pm Post subject: Power window switches |
Hello Crew!
I am in need of 2 power window switches for my TA (1983), Does anyone have access, or a trusted source for that type of part.
I'll buy them from you, or barter a crew hat or 2!
Mine are still functioning...barely... the housing is cracking on both and the passenger switch is in BAD shape and is hit and miss it's definately on the way out, the motors are new and work great, but i still need the switches!
Console mount, black.
I have been told the Camaro switch is compatible, but i'm not sure, input is truly appreciated!
Thanks Rich _________________
Posted: Thu Feb 12, 2009 7:23 am Post subject: |
I think GM still sells the switches. I don't have any though. _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 12, 2009 10:00 am Post subject: |
Hey Paul, thanks for checking your stash, i appreciate it.
I had my source at weston's do a search and so far zip.
I did look on ebay and found a new pair, i don't have an account, and have never been a big fan, however i may have to reconsider.
The ebay seller has the stock part number to compare.
I will send you the link, let me know what your opinion is.
Thanks
Posted: Thu Feb 12, 2009 5:01 pm Post subject: |
FYI, GM stopped selling the switches over the last year. I checked for Fish last year for his 87 and they were still available. Now they're not. And also, the 82-84 switches look different than the later ones... The earlier are all black and a little more square. _________________
Posted: Fri Feb 13, 2009 7:35 am Post subject: |
Thanks for the input i really appreciate it. You're right there Ian, not a dealer in North America has any, my source checked!
Al has a contact through EBAY, and i also found an after market that will
work, through Classic Industries.com new at 20.00 each, and i can
use my UPS and get then here over night, Life is good
Thanks again Crew!!
Rich
PS Headers are on!, new shiney valve covers are on, and in the tune
up stage, Cya at Dyno! _________________
