Delco Radio Illumination - White to Red
PostPosted: Sat Jan 24, 2009 9:07 pm    Post subject: Delco Radio Illumination - White to Red Reply with quote
I had this wild idea that I wanted the interior lights for gauges and dash to be red instead of white and came up with this Cool
I took the faceplate off from the semi-stock radio in my 89 this afternoon to figure out how to change the color of the backlight on the controls. Changing the bulbs was out of the question, they're soldered to the circuit board behind the faceplate as you can see here...
I took the faceplate apart further and saw how the light gets through the buttons and switches, then used model paint to color the backs of buttons and other spots the light shows through...
End result is red labels on everything when lighted from behind. I did the same to my defrost switch. I colored the bulb behind the HVAC controls, but it needs an LED now and so do the gauges
PostPosted: Sat Jan 24, 2009 11:14 pm    Post subject: Reply with quote
That looks cool Al.
PostPosted: Sat Jan 24, 2009 11:27 pm    Post subject: Reply with quote
That looks awesome! I need to do something to my interior lights. Everything is really dim at night. I'll pick your brain sometime about it. ~JAKE
PostPosted: Sat Jan 24, 2009 11:36 pm    Post subject: Reply with quote
The gauge cluster is pretty easy to brighten up. The lights reflect off the back of the metal bezel around all the gauges. Stock, it's painted a light powder blue, just repaint it a bright reflective color like gloss white or metallic silver - I painted mine silver, then the front side is red to give me red rings around the gauges.
I only have a picture of the front, but the back of this piece is silver
PostPosted: Sat Jan 24, 2009 11:41 pm    Post subject: Reply with quote
thats good work and good thinking ! looks really good ! wish you could change the colors on aftermaket cd players
PostPosted: Sun Jan 25, 2009 12:07 am    Post subject: Reply with quote
How hard is it to take that bezel off? Do you need to mess with the steering column?
PostPosted: Sun Jan 25, 2009 12:13 am    Post subject: Reply with quote
Eight torx screws in the front, then you have the lens and bezel which are held in with small hex head screws, 5.5mm. It all comes out the front and the only thing left holding the cluster in is the speedo cable and a pair of 10mm nuts down where the brake, seat belt, choke, lights are Cool
PostPosted: Sun Jan 25, 2009 12:16 am    Post subject: Reply with quote
just like my firebird wow they did do everything almost exact on the two styles huh Laughing
PostPosted: Sun Jan 25, 2009 12:20 am    Post subject: Reply with quote
You mean the radio??
That came from a 2002 Chevy/GMC truck. I had the truck slide brackets removed and added a couple of side brackets made from aluminum angle stock so it would mount.
PostPosted: Sun Jan 25, 2009 12:22 am    Post subject: Reply with quote
no i meant the way the inst cluster is held together i new the radio was out of a newer rig
PostPosted: Sun Jan 25, 2009 12:25 am    Post subject: Reply with quote
OIC
PostPosted: Sun Jan 25, 2009 4:23 pm    Post subject: Reply with quote
Those two nuts that holds the gauge cluster use a 10mm socket. They are sheet nuts.
Nice job Al. That looks really sharp. I'd like to do that to my HVAC controls too. How hard was it to take the cover of those off and what paint did you use?
I've got LED bulbs running my Autometer gauges. Something to match would be sweet in the HVAC.
PostPosted: Sun Jan 25, 2009 4:41 pm    Post subject: Reply with quote
In the HVAC, I just have a colored bulb, but an LED would be better (one of those #194 wide angle 5 LED assemblies). I've been toying with the idea of removing the plastic "lens" which the light shines through and somehow color it, but I need to first remove the ends from the slider controls. After that it looks pretty easy just to snap it out. The defrost switch was really easy, just take it out, pop the top, color the back side of the label and reassemble.
Timed exposure kind of enhanced the not very much light showing through the HVAC area. It lights up just enough to where you can see it in the dark.
The paint I used was a Testors model paint, I wanted to use a tail light paint, but the hobby shop I went to would have had to order it. I used a regular red that I already had.
PostPosted: Sun Jan 25, 2009 6:01 pm    Post subject: Reply with quote
That's sweet, Al.
PostPosted: Thu Jan 29, 2009 12:53 pm    Post subject: Reply with quote
thats cool i still need to replace all my gauge lights but last tuime i tryed i got couldnt get the speedo cable off then it started to rain and i had to put it back togeaher
PostPosted: Thu Jan 29, 2009 1:38 pm    Post subject: Reply with quote
Your 92 should be electronic shouldn't have a speedo cable (90-92). After removing the screws holding the gauges in, just lower the column a little and they should come right out. You should only have 4 lights for gauge illumination (the 89 has 11), plus the ones for all the indicators.
PostPosted: Fri Jan 30, 2009 10:05 am    Post subject: Reply with quote
ok ill try that
