91camaro_rs Member
Posted: Wed Dec 24, 2008 4:10 pm Post subject: Corvette Servo for 700r4 tranny |
| so i gettin a better tranny soon and i want to put a corvette servo in it but i was lookin on ebay and there are some for like 40 and some for like 160....anyone got any recommendations on where is the best place to get vette servos cause i dont really know what i am lookin for |
Posted: Wed Dec 24, 2008 5:05 pm Post subject: |
| Allegedly there's one in my burnt-up 700R4 sitting out back. I might go dig it out of the snowy scrap pile, pull the servo and grab some pics. |
91camaro_rs Member
Posted: Wed Dec 24, 2008 7:37 pm Post subject: |
| oh yeah, so since i am putting in a vette servo do i need a different torque converter? |
Posted: Wed Dec 24, 2008 7:41 pm Post subject: |
Servo swap = overdrive shift at WOT. Nothing to do with the converter. |
Posted: Wed Dec 24, 2008 7:43 pm Post subject: |
| You only need to change torque convertor to match the rpm range of your engine. So if you havent changed camshafts, then no need. The vette servo is just a piston that applies pressure to the band in the trans. The bigger the piston, the more pressure is applied. Vettes got a slightly larger piston then other cars. There are even larger servo's out there as well. Those are usually billet and $$. The actual vette servos are pretty cheap. Another common mod is to put in a vette tv sleeve, which gives you full throttle OD. I'd stay away from this. I put one in, and am going to put the old one back. You'll find that at certain highway speeds when you go to pass the trans won't shift down because of it. And if you think about it, just why would you need full throttle in OD? You can pretty much max out any road around here in 3d gear. |
Posted: Wed Dec 24, 2008 7:47 pm Post subject: |
Aaron, explained in my post, but the servo is actually the piston thats under the round cover on the side of the trans. The 4th gear lock in overdrive is the tv sleeve. The tv cable hooks to a piston which slides in the tv sleeve, which slides into the valve body with a few other springs and parts.
There's actually a groove on the outside of the sleeve. The length of the groove determines when 4th gear is disengaged. I think stock is like 3/4 but theres some variance. The groove goes by a port and dumps the hydraulic pressure to 4th gear when everything lines up. |
Posted: Wed Dec 24, 2008 7:55 pm Post subject: |
| My bad. My trans must have had the 'vette TV then, cause it would shift. I always figured it was the servo doing it. |
91camaro_rs Member
Posted: Wed Dec 24, 2008 8:26 pm Post subject: |
That will work. They make several different length pins. You may have to grind that one down to get the right clearance.. Too tight and the band will drag on the drum.
You putting a shift kit in? Because some kits come with the vette servo. |
91camaro_rs Member
Posted: Wed Dec 24, 2008 9:04 pm Post subject: |
| so can i get that valve kit and the servo?? and do you have to open the tranny or anything for the valve kit to go in cause i want to keep expenses down and not pay to have it put in...unless one of you guys knows how to do it? |
Posted: Wed Dec 24, 2008 9:09 pm Post subject: |
| skip the valve. I'm just showin what it is. Servo can be done from the outside.. barely when in car |
91camaro_rs Member
Posted: Thu Dec 25, 2008 9:19 am Post subject: |
| ok. ill just get the servo then |
91camaro_rs Member
Posted: Thu Dec 25, 2008 11:39 am Post subject: |
| ok so i am ready to buy the servo but one question emerged...is there a different servo for V6 trannys or are all the servos the same? |
Posted: Thu Dec 25, 2008 8:37 pm Post subject: |
So can someone explain to me what good having more pressure applied to the band is? Is it to handle more power before slipping or something?
~JAKE |
Posted: Thu Dec 25, 2008 9:04 pm Post subject: |
Yes the more pressure applied to the band increases its holding power. Also as was mentioned in the ad, if you tighten the clearances up it will take less time for the band to engage, speeds up the shifts involving the band.
As far as I know you can put the vette servo in the v/6 trans. Although that may actually be 2 steps stronger then what you have, ande probably overkill. I'd almost bet that the v/6 servo is even smaller then the v/8 camaro servo. |
91camaro_rs Member
Posted: Thu Dec 25, 2008 10:48 pm Post subject: |
| well i bought a vette servo for my v6 so we'll see what happens |
91camaro_rs Member
Posted: Tue Jan 06, 2009 4:53 pm Post subject: |
ok im going to get a tranny on sunday and i have the servo but i have no idea how this thing goes in. the instuructions dont even help
this is what i got (it came with the longer pin)
Posted: Tue Jan 06, 2009 6:49 pm Post subject: |
| On the side of the trans there's a round cover. You need to push in on the cover and remove the keeper thats around the outside. Then pull the cover off. It may just spring off. Inside that is the servo. There are various springs and pieces in there. You'll want to keep everything in order. Swap out the pieces you got new and reinstall. You may need to grind that pin to get the proper clearance. I forget just how to measure though. You may have to search tgo or team chevelle for a post on that. I think you just compress the whole works and measure how much it moves though. You don't want it too tight or it will drag the band on the drum. |
91camaro_rs Member
Posted: Tue Jan 06, 2009 9:02 pm Post subject: |
| ok so which side of the pin gets ground down the flat end or the pointy end? |
