Posted: Fri Sep 05, 2008 6:39 am Post subject: Windshield Washer Fluid intank Pump question |
Would someone with the intank washer fluid pump kindly go pull the line off of the pump and see if fluid comes out?
I built a washer fluid tank custom and fit the pump to it like factory. Filled it with water to check for leaks and fluid comes out the pump output.
Don't know if this is normal.
Thanks
-Paul |
Posted: Fri Sep 05, 2008 4:39 pm Post subject: |
| Ya.. they do that paul. |
Posted: Fri Sep 05, 2008 5:26 pm Post subject: |
| So mount it below the squirters eh? |
Posted: Fri Sep 05, 2008 8:05 pm Post subject: |
| not sure how you would go about mounting it above the squirters.... |
Posted: Sat Sep 06, 2008 10:28 am Post subject: |
| Dewey316 wrote: | | not sure how you would go about mounting it above the squirters.... |
Posted: Sat Sep 06, 2008 11:31 am Post subject: |
Well you've seen pictures of that honda crx with the home made turbo mounted about 6" above the hood, right? Same idea!  _________________
