GREG DAVIDSON Member
Posted: Tue Sep 02, 2008 10:36 pm Post subject: smokes a bit |
my 90 305 tbi smokes quite a bit at idle and start up specilly since i put our bulk oil of 5/30 chevron oil in from work eh it was free it is burning some oil but nothing more typical than a car with over 155000 miles on it its blue anthing to really worry about ?? i know they smoke anywho |
Posted: Wed Sep 03, 2008 7:32 am Post subject: |
Smoke on startup, or the 'chevy salute', is often attributed to worn valve stem seals. I would keep track of the consumption, that is how many miles before you have to add a quart of oil to top off, for a period of time to determine if it is excessive.
If usage is excessive it may indicate a more serious issue. For what it is worth, My brand new 1988 Trans Am gave the chevy salute about 10k miles into it's life. Was never really an issue, just a bit embarassing
Posted: Wed Sep 03, 2008 9:54 am Post subject: |
| blue89 wrote: | I'm sure the 5/30W has something to do with it.
x2. The IROC isn't an oil burner (yet), but I noticed a substantial pressure increase when going from 5W30 Mobile1 to 10W40 Royal Purple. |
Posted: Wed Sep 03, 2008 9:57 am Post subject: |
| how is that roysal purple stuff ? i was thinking bout trying it out if i ever get my engine rebuilt , but im deff going to switch it over to my normal castol syntec this weekend when i get paid |
Posted: Wed Sep 03, 2008 9:59 am Post subject: |
| I would just get some Delo 400. |
Posted: Wed Sep 03, 2008 10:04 am Post subject: |
You can get three quarts of Delo for the price of one quart of RP, Greg.
Paul was mentioning hot pressure problems with the Delo, but my RP still only has maybe 13-15psi at 750rpm when fully hot. |
Posted: Wed Sep 03, 2008 10:06 am Post subject: |
| i know we have 15/40 delo at work we use in the deisels i hust firgured it was way to thick |
Posted: Wed Sep 03, 2008 10:11 am Post subject: |
That is wahat i am running, is the 15/40 Delo. i am not having any issues.
But, my motor does have 240k miles, and gets abused pretty good. |
Posted: Wed Sep 03, 2008 10:18 am Post subject: |
| little to thick for my liking right now i'll put thicker in it this time if it keeps up the smoke i'll try the lucas oil stuff again i've seen it work before maybe i'll get lucky |
Posted: Wed Sep 03, 2008 10:33 am Post subject: |
| for oil, 15/40W would be a viscosity rating of 15 hot and 40 cold right? Since 15 is nearly stock it wouldn't be very thick at all but almost right? |
Posted: Wed Sep 03, 2008 10:34 am Post subject: |
15 cold, 40 hot.
We live in a pretty temperate climate, so I don't worry about running a little heavier oil. |
fiveoformula Member
Posted: Wed Sep 03, 2008 10:46 am Post subject: |
The 5W-30 is probably a bit thin, does it make any valvetrain noises?
even a small block in it's prime, I would recomend atleast a 10W-30. _________________
'88 FORMULA |
fiveoformula Member
Posted: Wed Sep 03, 2008 10:54 am Post subject: |
Well it makes sense for oil to be thinner at start-up so the oil can quickly pump thru the engine so you don't have a dry start. _________________
'88 FORMULA |
mrpopo573 Member
Posted: Wed Sep 03, 2008 11:24 am Post subject: |
| Dewey316 wrote: | | I would just get some Delo 400. |
Delo FTW. I used it in my Miata due to their inherit lifter tap on cold start. (bad head design)
Delo worked great at keeping my motor clean and supremely lubricated. _________________
2000 Maxima SE 5 Speed VQ30
Posted: Wed Sep 03, 2008 2:08 pm Post subject: |
| i'll do the 15/40 delo soon and get back to you and let you know how it does thanks |
Posted: Wed Sep 03, 2008 10:14 pm Post subject: |
| blue89 wrote: | http://www.valvoline.com/carcare/articleviewer.asp?pg=ccr20040601ov
It seems counter intuitive that oil gets thicker as it heats up. Ah well. Learn something new (or things i forgot again) every day. |
The idea behind multi-viscosity oil is to keep the temp changes from having such a dramatic effect. The oil needs to "act" thicker as it heats up to keep it from thinning out drasticaly. |
Posted: Wed Sep 03, 2008 10:20 pm Post subject: |
How accure is your pressure gauge john? I've got the autometer on and it's pretty sensative. The Delo is definitely a low pressure high temp oil. Right off idle pressure is up though. Since I'm no cop car I don't idle around lol.
20w50 isn't too thick for around here. if we're in sustained 20F below temps maybe think about 10w. Especially on a high milage motor. |
Posted: Wed Sep 03, 2008 10:35 pm Post subject: |
i havnt seen 20 deg since i moved out here from wisc lol dont care to ever again i think i'll try the delo first just to see it could'nt hurt to much when i drive her to ptown for the meet then prob switch it when it gets a tid bit colder ... kind of an advantage of working at a quick lube |
