Code 34
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sat May 17, 2008 2:52 pm    Post subject: Code 34 Reply with quote
I hear that one cause is leaking injectors. Since I have a new fuel pump I was thinking thats the case. When its warm it will die at idle ( like when i pulled it into the garage today. Could be a TPS sw too is the word on the street. Any gut feelings on this? let me know if you need more info.
Thanks
~Don
PostPosted: Sat May 17, 2008 3:04 pm    Post subject: Reply with quote
Good ole code book calls MAF signal voltage or frequency low during cruise
OR
MAP signal low during ignition on
Check out which ever you have to begin with, past that and I'm not much help.
I left out the meaning for the carbureted option since you said you have injectors.
