Posted: Sat Mar 01, 2008 10:58 pm Post subject: Rear end progress.. |
I got the brake stuff removed from the new rear end, everything was pretty well shot. Driver's side rotor only had one friction surface (I believe that's why the car was in the wrecking yard). Over the last couple of nights, and today, I spent a couple of hours cleaning it up and getting it ready for new brakes. Monday, my new calipers arrive, and with the cores I have, I'll order the rotors and lines and cables. Except for replacing the gasket and changing the oil, as soon as I get the brakes, it's ready to go on the car. I just need a weekend with cooperative weather...
All cleaned up and ready for brake components.
 _________________ 92 Camaro
Posted: Sat Mar 01, 2008 11:16 pm Post subject: |
looks good Al! now too bad no one will ever see the nice shiny rearend. What gears do you got in there?
~JAKE |
Posted: Sat Mar 01, 2008 11:26 pm Post subject: |
Too much Red on there.
Hehe, nice work, can't wait for you to get that in! |
Posted: Sat Mar 01, 2008 11:50 pm Post subject: |
It's just a little better than my 3.08. It's a 3.23. I thought I'd go with a red/black theme
When I finally get to installing this, I think I'll also get the front off the ground and install all my new steering parts and poly bushings. |
Posted: Sun Mar 02, 2008 12:54 am Post subject: |
Blue boys just jealous Al. Looks good!
Posted: Sun Mar 02, 2008 10:18 am Post subject: |
| I replaced the gasket and emptied the fluid this morning. My parts guy wasn't sure how much it takes, so he sold me 3 quarts (better safe than sorry). How much gear oil does it take? I can't find a capacities chart that lists it. 2 quarts fills it to 2 - 3 inches from the cover with the pinion pointing down. |
Posted: Sun Mar 02, 2008 10:20 am Post subject: |
You're supposed to have it in the car essentially ( so pinion is roughly horizontal).... and you fill through the side plug until fluid starts coming out.
Typically it's around 2qts. |
Posted: Sun Mar 02, 2008 10:43 am Post subject: |
| when i had my rear out i filled it way too much and just let the extra out the plug once the car was on the ground. |
Posted: Sun Mar 02, 2008 10:45 am Post subject: |
| Thank you Paul. 2 quarts in, buttoned it up, turned it horizontal and removed the plug to check the level and oil just starts to come out. |
305 302eater Member
Posted: Sun Mar 02, 2008 11:13 am Post subject: |
what weight do you go with? Just asking cause I need to do mine soon? _________________ Thirdgenless |
Posted: Sun Mar 02, 2008 11:17 am Post subject: |
| Just got the stuff my parts guy at NAPA recommended (other than the expensive stuff). NAPA gear oil, SAE 80W-85W-90. |
305 302eater Member
Posted: Sun Mar 02, 2008 11:19 am Post subject: |
Ok just checking. I thought your suppose to run a posi additive also? _________________ Thirdgenless |
Posted: Sun Mar 02, 2008 11:23 am Post subject: |
It's got it in it, or so I gather from the bottle. "Recommended for a wide range of applications and is for use in manual transmissions and both regular and limited slip differentials." Straight from the label  |
Posted: Sun Mar 02, 2008 11:27 am Post subject: |
DO NOT RUN NAPA BRAND POSI/LIMITED SLIP ADDITIVE!!!!!!!
And I think the oil is just saying it's compatible. Not that it has it in it. Napa has their own tube/bottle of additive. STAY AWAY!
It's too slippery and your posi clutches will wear at a rapid rate.
Go to GM. Get the GM brand bottle of limited slip additive. Use about 3/4 of the bottle with 2 fresh quarts of fluid.
I didn't realize this was a posi rear.
I just run the Valvoline 85w90 with the GM additive.
Last edited by Twilightoptics on Sun Mar 02, 2008 11:28 am; edited 2 times in total |
I think you might still want a tube of the additive Al. Maybe Brandon will chime in , but I have always added the additive regardless of what oil.
BTW, that looks nice all painted up. |
Posted: Sun Mar 02, 2008 11:33 am Post subject: |
Thanks for the info..
Since I haven't added anything (didn't know about the stuff), I'll pick some up before I get this in the car. It's available at the parts counter at GM?? |
305 302eater Member
Posted: Sun Mar 02, 2008 11:44 am Post subject: |
Yeah thats what I've been told also just to run the GM stuff which westbay carries. _________________ Thirdgenless |
Posted: Sun Mar 02, 2008 12:41 pm Post subject: |
I've only ever seen it at GM, but we don't have a Westbay down here.
It's about $8 a bottle. |
Posted: Sun Mar 02, 2008 12:50 pm Post subject: |
West Bay is a Kitsap County operation. They actually bought out all the NAPA stores in the county so now all the West Bay stores also carry the NAPA name.
I found a bottle, it was $10 here. |
305 302eater Member
Posted: Sun Mar 02, 2008 12:54 pm Post subject: |
Yep. I liked it better when it was just westbay. _________________ Thirdgenless |
