Dyno Poll stuff.
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar
Does it work?
Jan 25th-28th works for me, and I plan to dyno.
66%
 66%  [ 14 ]
It works, but I am not going to dyno
28%
 28%  [ 6 ]
This weekend will not work for me. :-(
4%
 4%  [ 1 ]
Total Votes : 21
Mangus
1989 Pontiac Trans Am
PostPosted: Thu Jan 24, 2008 3:44 pm    Post subject: Reply with quote
83Z28BlackBetty wrote:
i can pm you my # and you can call me friday.
Please do.
Magman
1990 Chevrolet Camaro IROC-Z
PostPosted: Thu Jan 24, 2008 4:41 pm    Post subject: Reply with quote
Dewey,
Yes, the lifter valley seal, china wall. I always throw the cork stuff out and I laid a nice fat bead of Napa "Even Bead" across the front and back. Drove it last night after a 24 hour cure and today it's leaking. I'm about ready to slap some JB weld over it from the outside and press!
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
PostPosted: Thu Jan 24, 2008 5:01 pm    Post subject: Reply with quote
is it leaking from corners, I have always used right stuff, and never had an issue.
PostPosted: Thu Jan 24, 2008 6:03 pm    Post subject: Reply with quote
The HSR ridge is incredible smooth. You should scuff it up with some fine sand paper and make sure it's BONE dry before assembly. Even bead/right stuff etc will work fine. Lay your beads down, set your gaskets ontop, then add more silicone ontop of the gasket edges at the corner.
Then set the HSR on top and look down the intake ports to make sure the gasket is aligned.
No leaks.
Magman
PostPosted: Thu Jan 24, 2008 6:36 pm    Post subject: Reply with quote
I think I may have jumped the gun, I can't find a leak anywhere. Coil/dizzy/plenum are off and the back of the motor is dry. I just might make it yet. I'm putting it back together now then i'll go romp on it a bit and check for leaks.
383 RWHP / 372 TQ
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar All times are GMT - 8 Hours
Page 8 of 8
