Posted: Tue Oct 30, 2007 4:12 pm Post subject: long time posting, broken block, etc.... |
Well, as it turns out I did some massive damage...pictures will come as soon as my internet stopps being crappy.
Anywho, Tony was kind enough to take most of the pictures (perhaps he can post them?) since the camera needs new batteries and I'm a poor college student...I pulled 3 and 4's pistons and what's left of the rods out the other day...yeah...that's some serious breakage. Both the crank ends of the rods are in pieces...and they put some nice scarring in the crank. Damage is over .250" in the 3/4 rod journal. Guess I'll be tossing the crank. The connecting Rods on the 3/4 pisttons are fubared BIG TIME. the damage with the rods even took out part bore area on the block. Its no wonder this thing siezed!!!
Took some dial caliper and micrometer measurements of the bore, rods and crank. All the bearings on the rods/crank were standard size. Hmmm....The bore meausrement seems to be around 3.7-3.80ish... Makes me wonder if I had a 305 in there. The heads are both 354434 casting, which is an early 305 casting.
Had the Machine Shop and Automotive Machine teacher take a look at the block this week. The damage looks like its below the bottom of where the piston sweep is.Tony pointed out that both the rods are bend more than 40 Degrees off where they should be centered on the crank.
The block casting # suggests its at least stock 327/350's bore, but the pistons, seem to suggest it being a 305. I'm really not sure. On a different note, 4 and 7's first two rings came to pieces when I pulled them out of the bores, they were the two blowby queens. all the other rings came off the pistons in one piece, or two.
anywho, that's the update. _________________
Sellmanb Member
Posted: Tue Oct 30, 2007 5:04 pm Post subject: |
wow, that sounds like the gruesome murder you hear about on tv that you go "ewww... when do they show pictures?"
It is weird that the block casting number says it's a 350, but the pistons are for a 305.... that irks me (and kinda pisses me off, as I paid like 400 bucks for the longblock) |
Posted: Tue Oct 30, 2007 9:16 pm Post subject: |
this thread is useless without pics!!!!!!!!!!
this is what i saw when i got to chris' house.
tell your boobs to stop staring at my eyes.
note the chunk of the piston sleeve that is gone, and the chunk of the bottom of the block that is gone.
this is a shot past the crank at the bore, note the dent from where the rod smashed into it.
and lastly a wide shot. let this be a lesson to you, if you are an engine, stay out of chris's car.  _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Tue Oct 30, 2007 9:17 pm Post subject: |
Posted: Tue Oct 30, 2007 9:19 pm Post subject: |
the same thing you do with everything else john... shove it. =D
i can see them... lemmie investimigate, paul mentioned something about comcast being extra comcastic (sucky) about photos.
EDIT*
i don't know. i used to be able too host viewable photos. i guess you can right click, "save as" and look at them on your desktop. |
Posted: Tue Oct 30, 2007 9:43 pm Post subject: |
That's quite the carnage  _________________ 92 Camaro
Posted: Tue Oct 30, 2007 9:45 pm Post subject: |
Once I right clicked and opened one, all the pictured showed.
I think you should tell comcast to shove it.
--John |
Posted: Tue Oct 30, 2007 9:47 pm Post subject: |
Nasty. What's the plan now?
-Schultzy |
Posted: Tue Oct 30, 2007 10:11 pm Post subject: |
Plan now is new motor....
I'm not sure which is better to go with. I have the block that came out of the car, which is a 2 bolt main that has the 010/020 in the timing cover area. If it truely is a 327/350 block; based on the measurements I took of the pistons, I think its gotta be pretty close to standard bore (Rod and main's were also STD). The other block I have is a 4 bolt main but it only has a "010" number in the timing chain area and I haven't tried to stuff one of the pistons down the bore, so I don't know the size.
Reguardless, both blocks are gonna have to be checked for cracks, size and trueness of bores and be hottanked. I'm leaning towards the 4 bolt block I have as my usable core, but the 2 bolt is a high nickle/tin, and if the damage to the bore won't effect the block....I don't see any reason not to use it.
Right now, I'm just figuring out which block to use and then go from there. _________________
Posted: Wed Oct 31, 2007 6:00 am Post subject: |
Sell both blocks in favor of an LSx...
Oh wait. Do I always say that?
That's some nasty chocolate you got there! |
kenf729 Member
Joined: 22 Mar 2007 Posts: 88 Location: Forest Grove, Oregon
Posted: Wed Oct 31, 2007 8:32 am Post subject: |
Wow, in that 5th picture, the crank really smaked that rod hard enough to take a piece out of the block, bust a chunk off the piston sleve and dent/hole in the oil pan, not to mention dent the heck out of the crank it's self...bet that made quite a bit of noise? _________________
STEEL Member
Posted: Wed Oct 31, 2007 8:40 am Post subject: |
| Nice.... Just, nice... |
Posted: Wed Oct 31, 2007 9:43 am Post subject: |
| kenf729 wrote: | | Wow, in that 5th picture, the crank really smaked that rod hard enough to take a piece out of the block, bust a chunk off the piston sleve and dent/hole in the oil pan, not to mention dent the heck out of the crank it's self...bet that made quite a bit of noise? |
Yeah, sounded like popcorn popping, not to mention the car bucking and shivering like crazy. _________________
Posted: Wed Oct 31, 2007 2:18 pm Post subject: |
| Didn't you say the blown motor... the block had a crack in the cylinder wall? |
Posted: Wed Oct 31, 2007 2:42 pm Post subject: |
wow, looks like your engine wasn't getting along with you all that well. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Oct 31, 2007 4:29 pm Post subject: |
If you are going SBC you should really price out stroking it. I think you will find that it will not be that much more. LSx is nice if you can get into it right. Even a stock LS1 will be a very very nice upgrade.
Posted: Wed Oct 31, 2007 4:44 pm Post subject: |
If you have to buy a crank/rods/pistons....
383 is the same cost.
Just a little block work. |
Posted: Wed Oct 31, 2007 7:23 pm Post subject: |
| Twilightoptics wrote: | | Didn't you say the blown motor... the block had a crack in the cylinder wall? |
was an optical illusion...can't see any visible cracks running up the bore now that the crank is out. _________________
Posted: Wed Oct 31, 2007 7:25 pm Post subject: |
383eh?
I'd like to be able to spin this thing up to 6k without problem, and I think the extra machine work might put me over my budget too.
I'll definately take it into consideration though. _________________
Posted: Wed Oct 31, 2007 7:58 pm Post subject: |
| What extra machine work? There isn't anything different for a 383 than for a 350. Just the parts. Modify the block for clearance yourself. Also depends on of if you use 6.0" rods or 5.7" rods. |
