95-98'ish vortec 350, anyone here worked on one?
PostPosted: Fri Aug 31, 2007 4:11 am    Post subject: 95-98'ish vortec 350, anyone here worked on one? Reply with quote
Needing advice on stabbing the dizzy for one of these. I know they have to be in very specific, and this is the part of motors I am not good at.
Does the factory hold down put it in its propper place, or is it like any other sbc and I can spin the dizzy however?
:help:
Sellmanb
PostPosted: Fri Aug 31, 2007 6:36 am    Post subject: Reply with quote
it's like a SBC, but if you stab it in wrong, the computer will compensate for the mechanical timing, electrically. But it will throw a code. In order to properly set the timing, you want it at 0 degrees, so you just watch what the PCM sees as base timing with a scan tool, move the scan tool to the engine bay, move the distributor till it says 0, then tighten the distributor down. Clear the code afterwards.
BTW, i'm guessing this is for your truck?
PostPosted: Fri Aug 31, 2007 6:45 am    Post subject: Reply with quote
Hey now, what do you have cooking in your garage? I have the 97 in the Tahoe, but I know nothing about it. How do you take the dizzy apart to find out if its at 1?
PostPosted: Fri Aug 31, 2007 7:05 am    Post subject: Reply with quote
blue89 wrote:
Hey now, what do you have cooking in your garage??
Twisted Evil There are 2 small torx screws that takes the dizzy cap off. Becareful these screws are not clipped into the cap and get lost often.
Thanks Sellman. I wont be having a live scantool on it for prob another 2-3 weeks after I hope to have it running. So I guess I will just have to do my best at guessing. No, this is not for my truck Wink
Am I correct that #1 on the rotor changes form pointing right-front(standard sbc) to left-front(vortec sbc)?
PostPosted: Fri Aug 31, 2007 7:12 am    Post subject: Reply with quote
is this for the "top secret project" WinkWink
if so...sweeeeet
PostPosted: Fri Aug 31, 2007 7:17 am    Post subject: Reply with quote
Heres whats cooking Twisted Evil
95 model cast 683, 350 block
810 heads
108deg ICL cam
All above known as GM crate motor.
90-92 Z28 TPI intake
86-93 camaro MSD coil
93 Camaro z28 plug wires
96 c1500 timing cover
96 c1500 dizzy
96 c1500 maf
96 c1500 ICM
96 c1500 egr (not at first)
96 c1500 heated o2 sensors
96 c1500 harmonic balancer
2001 express van wire harness
2001 express van knock sensor
GM 0411 ECM (same as vette and LS1's)
Later, I have headers that need y-pipe ball flanges to install.
PostPosted: Fri Aug 31, 2007 7:37 am    Post subject: Reply with quote
I love pics of parts piles Very Happy
That looks good. OBDII just like my Tahoe. Would it be advisable to go to the standard dizzy instead of the crab? I don't know anything about that system yet.
PostPosted: Fri Aug 31, 2007 7:41 am    Post subject: Reply with quote
Your hoe uses a different ECM/PCM. However, I forget, some years you can just repin the harness and make it work with the LS1 unit.
You have to use the crab dizzy because it has a cam sensor in it.
I am the first to try and use the old style coil with a newer system. Old coil has more power *tim allen grunt*
PostPosted: Fri Aug 31, 2007 9:35 am    Post subject: Reply with quote
you said its "vortec 350"?
I assume it uses the standard SBC intake mounting pattern and not the vortec style?
PostPosted: Fri Aug 31, 2007 9:37 am    Post subject: Reply with quote
The dizzy, timing cover, and everything listed above for a 96 c1500 is off a vortec.
As you see above, I listed 810 heads, which is standard SBC heads.
PostPosted: Fri Aug 31, 2007 9:39 am    Post subject: Reply with quote
Ah.....couldn't quote casting numbers off the top of my head, but it looks like you'll have a pretty sweet setup there when all's said and done.
PostPosted: Fri Aug 31, 2007 12:03 pm    Post subject: Reply with quote
Thats cool.
The 810 heads are TBI swirl ports. Not that great in the HP spec, but very decent for TQ, which is what I'm going for.
The cam doesnt have the greatest lift. But that can be easly changed down the road.
