kenf729 Member
Joined: 22 Mar 2007 Posts: 88 Location: Forest Grove, Oregon
Posted: Sun Jul 15, 2007 8:22 am Post subject: |
| Al Hasse wrote: | Did the driver's door today. $6 for the pin & bushings and $10-$15 for a spring tool. Used a floor jack to lift the trailing edge of the door, undid the upper hinge, then got the door positioned so the pin loose in the hole (really bad sag), and pulled the pin up with a set of channel-lock pliers. Looks like I have to replace the detent roller now too, it doesn't roll.
For those looking to do this, the pin & bushings are in the "HELP!" section, the ones they sell for our cars is part # 38402. That was too small for my car and I had to use the oversized kit, part # 38407. I also highly advise getting a door spring tool, makes life much easier. |
Al, what store did you buy these at or did you get them on line somewhere. I sure would like to do both doors but can't afford 150 bucks at this time, but i sure could afford 30 bucks!!!
Ken |
Posted: Sun Jul 15, 2007 8:30 am Post subject: |
Most parts stores have a "HELP!" section. I bought mine in West Bay Auto Parts' HELP! products line. It's the section where you find all the body panel fasteners and such. _________________ 92 Camaro
kenf729 Member
Posted: Sun Jul 15, 2007 8:49 am Post subject: |
| Thanks, I think I will head down to AutoZone to see if they have that part number... |
Posted: Sun Jul 15, 2007 9:33 am Post subject: |
| Did you only redo the bottom hinge Al? That looks like the kit for it. You can get it most anywhere.. Rebuilding the top hinge is the spendy one. |
Posted: Sun Jul 15, 2007 9:38 am Post subject: |
Top hinge seems to be in decent shape yet. I still need to do the roller on the driver's side, that looks like either a GM part or one from TDS. _________________ 92 Camaro
cdoyle New Member
Posted: Thu Aug 09, 2007 7:42 pm Post subject: |
My door was sagging bad, so I first bought the lower pin at autozone or one of those places. Got it in there, and it didn't do a thing.
So spent the money and got the TDK kit. Took about 45 minutes with my dremel getting the old one out. But once the kit was installed, my door was perfect again. It's been so many years since that door has closed right, I couldn't believe how easy of a fix it was.
I totally recommend getting the TDK kit. Plus they have grease zerks, so it'll last a long time. _________________ Show off your ride and all the work you've done |
