how do i change out my U-joints?
PostPosted: Tue Jul 17, 2007 7:37 am    Post subject: how do i change out my U-joints? Reply with quote
like i said. I got new ones but am not sure the best way to start this project.
thanks,
Mangus
1989 Pontiac Trans Am
PostPosted: Tue Jul 17, 2007 9:20 am    Post subject: Re: how do i change out my U-joints? Reply with quote
thanks,
Unbolt the clips (2 per end) that hold the u-joints to the yoke and pinion and pull the u-joint 't', replace them with the new ones, and use new clips to re-attach them.
If you don't have one, a Chilton's or Hayne's manual will go a very long way. =) I have both (and the factory service manual, which are very expensive for our cars).
PostPosted: Tue Jul 17, 2007 9:35 am    Post subject: Re: how do i change out my U-joints? Reply with quote
haha cool thanks. I was worried that i would have to drop out the rear end. Razz
Mangus
PostPosted: Tue Jul 17, 2007 9:38 am    Post subject: Re: how do i change out my U-joints? Reply with quote
Nope, it's pretty simple. It will probably take you 15 minutes (30 if you've never been underneath a car).
82camaro383
PostPosted: Tue Jul 17, 2007 10:17 am    Post subject: Reply with quote
If you are still using the factory u-joint, you have to heat them with a torch to remove them from the driveline. I had to change mine a week ago.
85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph
Sellmanb
PostPosted: Tue Jul 17, 2007 11:39 am    Post subject: Reply with quote
there's little "plastic" dots on the driveline at the end holding the u-joints in. Heat up around that area lightly until it starts to ooze out of those dots. Then you can just pry up on the u-joints and replace.
Dont go hog wild w/ the heat, it will degrade the metal and make it more prone to becoming out of phase the more heat is applied.
Mangus
PostPosted: Tue Jul 17, 2007 11:42 am    Post subject: Reply with quote
Oops, yeah, as the others pointed out, there is a little bit of coersion involved.
PostPosted: Tue Jul 17, 2007 2:14 pm    Post subject: Reply with quote
torch? Shocked what am i melting in there? am i gonna have to replace whatever I'm melting?
Mangus
PostPosted: Tue Jul 17, 2007 2:38 pm    Post subject: Reply with quote
Grease. Yes, you need to replace the grease. The needle bearings need to be packed well w/ grease. Some u-joints come with zerk fittings, in which case you can grease it after installation.
izcain
9sec Club
PostPosted: Tue Jul 17, 2007 4:34 pm    Post subject: Reply with quote
You'll want to put a scribe mark in one side of the pinion and drive line to give you a reference point since some drive lines were a balanced fit. It is a good habit to make even if the drive line is perfectly balanced occasionally you will come across some that aren't.
9.17 @ 148
Sellmanb
PostPosted: Tue Jul 17, 2007 6:29 pm    Post subject: Reply with quote
What you're melting is (as I understand it) a sort of hard teflon. Once it's out, there's no injecting it back in, thus why new u-joints come w/ clips to hold them in place, that werent there before.
As for greasing the joints, that's always a good idea if you have a zerk fitting on the joint. If you dont have a zerk fitting on the joint, then dont worry about tapping one in, it's just not made to have one.
PostPosted: Tue Jul 17, 2007 9:48 pm    Post subject: Reply with quote
Take it to a driveline shop. Period.
It will need a balance. You can't get our style in there perfect to have it like factory. Sometimes you can get lucky.
If it was the clip style like the 60's 70's era then yeah you can do it yourself just fine.
Brandon has experiance with the lack of balance too!
Driveline shop I've been too is very reasonable. U-joints are a headache to do yourself anyway.
PostPosted: Tue Jul 17, 2007 10:05 pm    Post subject: Reply with quote
GM didnt bother machining our yokes true. They used a jig that held the driveline straight then pushed the u-joint in centered. The plastic was then injected to hold the u-joint in that position. Sometimes when you put a replacement joint in you'll get offcenter, because the joint is now centered with the clips on the inside of the yoke. Mine is this way. Get over 85 and things get rough. Wasnt this way before changing the u-joints. I got a nice chromemoly shaft to put in to cure this.. too bad its 2" too long at hte moment.
Sellmanb
PostPosted: Wed Jul 18, 2007 6:23 am    Post subject: Reply with quote
For the cost of a driveline shop (and having to drive to the shop if there's none near you) you could get an aluminum LS1 driveshaft for roughly the same price (I'd seen them about a year ago going for ~85 dollars). May be a better way to go, less headache, more go-fast Wink
PostPosted: Wed Jul 18, 2007 9:20 am    Post subject: Re: how do i change out my U-joints? Reply with quote
Mangus wrote:
*snip*(and the factory service manual, which are very expensive for our cars).
wow, i was about to link to helm, where they are 35$. but they are 75$. price went up since i got mine. Shocked
Mangus
PostPosted: Wed Jul 18, 2007 9:30 am    Post subject: Re: how do i change out my U-joints? Reply with quote
Find me one for an '89 for less than $90 and I'll be impressed.
PostPosted: Wed Jul 18, 2007 2:12 pm    Post subject: Reply with quote
I went through 2 aluminum drivelines before I found one that wasn't bent. No driveline shop in the Vancouver/Portland area can UN-bend aluminum drivelines. You don't even want to know what it costs to have a new tube welded on around here. Might as well buy a carbon fiber.... or two.
So unless you're lucky, an aluminum is not necessarily the way to go. I never noticed a single bit of difference putting one on, plus it's bigger and in the way. When I go with the 9" I'm sure I'll shred this one, and be getting a steel driveline with larger joints in the back.
PostPosted: Wed Jul 18, 2007 4:18 pm    Post subject: Reply with quote
My experience was totally different from yours. I got my aluminum shaft off a 90 GTA in a wrecking yard for $45. Put a new rear u-joint in it and I noticed the difference in the smoothness and less vibration by the time I got into second gear. I'd read somewhere the aluminum shafts were balanced to a higher standard than the steel ones were. There were definately more balance weights on the aluminum shaft than on my old steel one.
PostPosted: Wed Jul 18, 2007 8:14 pm    Post subject: Reply with quote
Not sure about factory but I know some driveline shops down here balance at different rpms. I know one balances at 500rpm while another is over 3000rpm. Figure 4th gear is 1:1 so your driveline is turning at the rpm you're running.
PostPosted: Fri Jul 20, 2007 7:19 am    Post subject: Reply with quote
Got em changed out yesterday, much more of a pain than I thought. I ended up beating the sh*t out them to get em out! turns out that wasn't the knocking I've been hearing all along Sad oh well, at least I know I have good U-joints now.
BTW, one of em is a bit squeaky... Confused is it cuz i zerked in too much grease? or not enough? I hope I'm not killing my new u-joint.
