Valve Cover trouble...
Project_1986_TA
PostPosted: Mon Jan 19, 2004 2:56 pm    Post subject: Valve Cover trouble... Reply with quote
Not sure if iv posted this before but i bought some Edelbrock valve covers a while back and havent been able to put them on because the old ones wont come off. I have tried prying but cant gain to much leverage because i might break the exhaust manifold. Is there a certain trick to getting these things off? They wont budge at all!
View user's profile Send private message Yahoo Messenger MSN Messenger
widow_maker89
New Member
PostPosted: Mon Jan 19, 2004 3:15 pm    Post subject: Reply with quote
i had the same trouble on my car. On mine at least it was cause by two things....One, the gaskets had sealed to both surfaces and neither wanted to give, and two the lip of the vavle cover was caught under the lip of the intame manifold or runner...
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Project_1986_TA
PostPosted: Mon Jan 19, 2004 7:15 pm    Post subject: Reply with quote
Im pretty sure its not stuck under the intake manifold so how would i go about getting them off if its the gaskets stuck to both sides? I tried just about everything from trying to pry it to nocking it loose and no luck at all.
PostPosted: Mon Jan 19, 2004 7:46 pm    Post subject: Reply with quote
Some stick so hard you have no choice but to bend the cover up a bit. Try to get a screw driver between the head and gasket... If its a cork gasket you should be able to get a driver through the cork. Once its through pry up a bit.. You may have to insert the driver in multiple places before you can get it to come loose. Have a fun time scraping all that off when you finally get it.. Good Luck
PonchoTA
PostPosted: Mon Jan 19, 2004 8:00 pm    Post subject: Reply with quote
Rubber hammer! On the front corner nearest the intake, hitting towards the brake booster (on drivers side) or A/C dryer (pass. side)
Over and over and over until it comes loose!
hth
PostPosted: Mon Jan 19, 2004 8:04 pm    Post subject: Reply with quote
I could never hammer stuck ones loose, always pry with a screw driver.
Unless you are replacing the covers, then beat the S*** out of em!!!! Laughing
TecherB
Princess B
PostPosted: Mon Jan 19, 2004 10:35 pm    Post subject: Reply with quote
big hammers you said that you are replacing them
just dont hit other things
whare is "the hammer" at a time like this
90RSrocks
PostPosted: Mon Jan 19, 2004 10:55 pm    Post subject: Reply with quote
LMAO no kidding there!
Arrow Smashy Smashy Very Happy
Demon
PostPosted: Tue Jan 20, 2004 2:04 am    Post subject: Reply with quote
guess i never really had a problem with mine...
but if they stick, if there is a hole for the a breather, just use a crowbar and pry outward a bit the length of the cover depending on where the hole might be...
though its more entertaining to pound the hell out of something I'm sure... hehe...
but instead of using a screwdriver, invest in a half inch wide chisel with a bevelled edge... hammer that in a few times and pry...
bit stronger i would think Smile
or use the crowbar that way too Surprised
PostPosted: Tue Jan 20, 2004 4:09 am    Post subject: Reply with quote
that is because you didn't have ramrod helping you Wink
if they are REALLY stuck, get rodney and his hammers to come pay you a visit.
he LOVES to go after other peoples car with a hammer Wink
