Red Bird Member
1991 Pontiac Firebird
Posted: Sat Jun 23, 2007 6:28 pm Post subject: Car wont start! autocross tommorow |
So my 91 lo3 firebird, has been acting weird. I went to get gas, filled up hopped in to start it turn the key, and nothing. i push started it to get it home. i pulled the starter and took it down to get tested. they said it was fine. Put the starter back in and car started right up. i went for a cruise and parked shut it off, turned back on fine. I took her down to wash her today. after i was done turned the key and nothing just a click. waited a while about 25 min started fine. went home shut it off and tried it again started fine. I am headed to packwood for an autocross tommorow and i just dont want it to do this to me while im in the grid. has anyone run into this problem? i checked all the connections to the starter and they all seem fine. Any ideas thx in advance _________________ 1991 Firebird L03 T-5 |
Posted: Sat Jun 23, 2007 7:55 pm Post subject: |
| Sounds like a heat soak problem with the starter, works fine cold but not when it gets hot. Probably time for a new one. |
Red Bird Member
Posted: Sat Jun 23, 2007 8:40 pm Post subject: |
I was thinkin the same thing, i just didnt want to shell out the dough before i was sure that was the problem. i might try and make a heat sheild for it this evenin so i can get thru tommorow. are their any other parts that are not related to the starter besides the alternator and battery that would keep the motor from trying to turn over? _________________ 1991 Firebird L03 T-5 |
Posted: Sat Jun 23, 2007 9:22 pm Post subject: |
Had the exact same problem with my IROC. I'm currently swapping to an LT1 starter to try and eliminate it.
As for other parts: starter solenoid, coil, coil wire, battery cables, starter connections. Lots of stuff to go wrong. |
BigDaddyVu 12sec Club
Posted: Sun Jun 24, 2007 10:52 am Post subject: |
| most likely your a lil advanced on the dizz |
Posted: Sun Jun 24, 2007 11:22 am Post subject: |
| BigDaddyVu wrote: | | most likely your a lil advanced on the dizz |
Or the starter is about dead. |
Posted: Sun Jun 24, 2007 12:39 pm Post subject: |
| well i had that problem for years and i thought it was due to my headers i found out it was my dizzy i replaced it in feburary after years of replacing the starter ever year and haven't had a problem since and i a am drag racing with no problems. |
Posted: Sun Jun 24, 2007 5:19 pm Post subject: |
i had trouble starting when the dizzy on the six was going all wonky (losing/gaining 15+ degrees of timing at random). but the starter always worked, the engine was just "fighting" with it. it sounded labored. that being said, labored starting means your starter is working hard, and will wear down faster. all the more reason to check your timing often. if your car has 150K+ your dizzy could probably use a re-build.
this does not sound like a spark issue at all since the starter is failing to turn over. you said you heard a click, that is the starter solenoid clicking over. this means you are getting power that far. i would say almost 100% that your starter motor is where your problem is, just like Rodney said.
while you have the starter out check your connections and wires, if any are really close to hot things this can cause the connections to be weaker once hot. (hotter wires have higher resistance) _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Sun Jun 24, 2007 6:29 pm Post subject: |
| if you had the timing retarded the motor wouldn't crank it will iginite the mix before the piston reaches TDC. |
Sellmanb Member
Posted: Sun Jun 24, 2007 6:44 pm Post subject: |
If you mucked with the timing enough so that it made the motor run much hotter, then in theory the starter would get hotter, quicker because of the extra heat from the exhaust.
Therefore, the problem would start at the timing, and end with the distributor.... in theory.
I'm w/ Rod on this one though, get yourself a mini-starter and be done with it. |
Posted: Sun Jun 24, 2007 6:46 pm Post subject: |
wouldn't it still sound like it was trying to crank though? ... he said he only hears a "click".
mine just got labored, so it must never have been before top dead center.  |
Posted: Sun Jun 24, 2007 8:09 pm Post subject: |
Heat soaked starter +1 _________________
Posted: Sun Jun 24, 2007 8:38 pm Post subject: |
| BigDaddyVu wrote: | | if you had the timing retarded the motor wouldn't crank it will iginite the mix before the piston reaches TDC. |
Other way around, too far retarded and it might not even start, just spin over. To far advanced and it will get real hard on the starter.
I had to go with a gear reduction mini starter when I modified the mech advance in my distributor. Base timing is 28*, stocker just wouldn't do it.
His starter sounds like heat soak though. |
Red Bird Member
Posted: Wed Jul 04, 2007 5:19 pm Post subject: |
We cruised up to packwood, and it was raining and pretty cold all day. I didnt have any issues with the starter in the grid or on the way home. I picked up some header wrap and wrapped it around the ypipe next to the starter, and it hasnt happened since. _________________ 1991 Firebird L03 T-5 |
Posted: Wed Jul 04, 2007 11:07 pm Post subject: |
| just a heat soak issue. good job getting it cleared up. |
