STEEL
PostPosted: Sat Jun 16, 2007 11:46 am    Post subject: Wheels and Tires Reply with quote
Well, I am planning my big build up when I get back from Basic, and I am planning on replacing two of the wheels, and I think it will need rear tires by then.
What are the best wheels for my car? I have the stock wheels on there now, but the ones on the passenger side are chewed up. To me, a good idea would be get four more just like them, get some All Weather Tires on four, then the other two could get some Nitto Drag Radials.
What size can fit? is there anything else i should know?
PostPosted: Mon Jun 18, 2007 8:04 am    Post subject: Reply with quote
Tough question, as a lot of this depends on your preference and what you are going to do with the car.
For example, my LT1 was a daily and I wanted it to look good. It got heavy 18x8's that look good on the car. My V6 car is a play car and needs to go fast, so it got crosslace 16x8's. 14lbs lighter a wheel!
If I had to do it again, I would get crosslace corvette wheels at 16x10! Get some 275/45r16's and you'll never need to get bigger.
PostPosted: Mon Jun 18, 2007 5:56 pm    Post subject: Reply with quote
Single-vein IROC's ftw!!! Very Happy
PostPosted: Mon Jun 18, 2007 6:20 pm    Post subject: Reply with quote
FWIW 17" C5 Wheels and 16" IROC single veins with rubber weigh exactly the same.
STEEL
PostPosted: Mon Jun 18, 2007 6:24 pm    Post subject: Reply with quote
Like these? Then what size tires can i put on there?
PostPosted: Mon Jun 18, 2007 6:28 pm    Post subject: Reply with quote
I've got 245/50 R16 on there.
It's a 16x8 Wheel.
If you want fatter tire, you need bigger wheel. And you'll probably end up getting wheel spacers to make them fit.
STEEL
PostPosted: Mon Jun 18, 2007 6:47 pm    Post subject: Reply with quote
Well, I don't want flatter tires, just wider, can you go any bigger than 245 in the back?
PostPosted: Mon Jun 18, 2007 8:50 pm    Post subject: Reply with quote
You don't want them flatter? Lol.
10" wide is easy on the rear. But can you go 12's?
STEEL
PostPosted: Mon Jun 18, 2007 9:35 pm    Post subject: Reply with quote
10 or 12 inch?!
O.O
What kind of modification is needed to make that work?
PostPosted: Tue Jun 19, 2007 7:41 am    Post subject: Reply with quote
10's are easy to fit back there. Thats only a 275 rear tire. Putting 315 back there requires careful backspacing measurements and maybe rolling the fender. It has been done before though. I think CheezX has 315's. Try to get a hold of him to see what he did.
PostPosted: Tue Jun 19, 2007 8:18 am    Post subject: Reply with quote
STEEL wrote:
10 or 12 inch?!
O.O
Hell, you saw my rear tires. Those are 295's and with some more massaging and a wheel lined up with the fender (mine tucks just a bit) I'm sure you could stuff 305s, 315s or wider maybe.
PostPosted: Tue Jun 19, 2007 8:28 am    Post subject: Reply with quote
Isn't Jake running 305's on his car? I don't know if it's lowered though.
STEEL
PostPosted: Tue Jun 19, 2007 10:02 am    Post subject: Reply with quote
-double post-
STEEL
PostPosted: Tue Jun 19, 2007 10:03 am    Post subject: Reply with quote
Ok, I have been doing research! I found that tires prices start to get crazy on a 18 inch rim, so I have decided to go with some 17 x 9.5 inch. I like the Black ZR1s.
If I understand right (and I think I do) the best way I can do this is to get some ZR1s, 4 two inch spacers and then get me some 275/40/17s up front, and some 285/40/17 in the back.
Since I bake my tires regularly, rotating isn't an option anyway.
PostPosted: Tue Jun 19, 2007 10:14 am    Post subject: Reply with quote
I have 255/60 r15's and they are BF Goodrich Radial TA's. they look much bigger than they really are. They give it that old muscle car look though Cool
PostPosted: Tue Jun 19, 2007 3:21 pm    Post subject: Reply with quote
I'd like to stick 275's on the wheels on my car. Right now I think its sporting 225's in back.
Demon
PostPosted: Tue Jun 19, 2007 8:10 pm    Post subject: Reply with quote
go to www.tomzwheels.com for the black ZR1's... he has a reasonable price on the wheels and tires ...
I'm going to use him because I'm considering swapping off my Chrome ZR1's and just keeping them in storage and running the black ones myself
STEEL
PostPosted: Tue Jun 19, 2007 10:31 pm    Post subject: Reply with quote
hmm, link wont load, googled it, still wont come up, so the server is prolly down.
I will re-investigate tomorrow.
STEEL
PostPosted: Wed Jun 20, 2007 3:54 am    Post subject: Reply with quote
Ok, wow, how my engine build has evolved into a complete overhaul, I dont know, but its going to be fun!
So, this is my understanding. 315s can be run on ZR1s, it has been done, with no wheel well modification. The problem is, as I get more and more outrages, the less available information is. None of my searches have told me what size spacer I will need for sure.
I dont understand spacers completely, do I have to modify my studs?
I think I will probably order a few sizes, and then E-bay the ones that I don't need, hopefully I will get what I paid back out of them.
Can I go 12 inch rear tires? I think I can, I think I can, I think I can.
Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil
PostPosted: Wed Jun 20, 2007 8:21 am    Post subject: Reply with quote
Spacers are like a second set of wheel studs you bolt on that are farther out than stockers. If you want better info, contact I think his name is Andris? Owner of http://www.skulte.com/ and he'll be able to help you with sizing and wheel location.
