Good Grease?
PostPosted: Fri Mar 09, 2007 10:38 pm    Post subject: Good Grease? Reply with quote
What's a good all purpose grease?
I usually end up with this red stuff from valvoline but figure since I'm putting new wheel bearings in with the brakte setup, I should ask about grease.
Is there a good all purpose one to use on wheel bearings and chassis components?
Thanks
-P
PostPosted: Fri Mar 09, 2007 10:47 pm    Post subject: Reply with quote
I like the Lucas stuff we have at work. Not too spendy and its waterproof. Just using it on a bearing puller you can feel the difference in friction between it and regular grease.
There are alot better greases out there too. But this is better then average stuff and only $3-4 a tube. Some of this stuf like LE can cost $15-20 a tube.
Demon
PostPosted: Fri Mar 09, 2007 11:37 pm    Post subject: Reply with quote
I've been using this on my suspension, no complaints so far Smile
http://umiperformance.com/3008.aspx
