Wolffy Member
Posted: Fri Mar 09, 2007 5:48 pm Post subject: |
Holy crap! You'd better get the hacksaw out and start cutting that hood!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Mar 09, 2007 5:49 pm Post subject: |
is very nice. |
hehe cool man! Believe me I can understand your excitement but I sure hope you meant 'stoked'.
Posted: Fri Mar 09, 2007 5:50 pm Post subject: |
| Cool, now bolt that thing on your 305 and get all of the tuning mishaps out of your system before it goes on a built engine. |
Wolffy Member
Posted: Fri Mar 09, 2007 5:53 pm Post subject: |
| well hammer id luv to, but as i have no idea what compression ratio my 305 is running & i dont want to blow the bottom end apart finding out |
Posted: Fri Mar 09, 2007 5:58 pm Post subject: |
brass ones wolfy, brass ones.
IIRC unless it is not stock, it is probably 9.3:1
6-71 will be cool, just don't plan to see where you are going, that thing is going to be up blocking your view! |
| Wolffy wrote: | | i dont want to blow the bottom end apart finding out |
Why not? that sounds like a good old fashioned fun time.  |
Posted: Fri Mar 09, 2007 6:11 pm Post subject: |
Tony's got the same idea i got.. why not??  |
Posted: Fri Mar 09, 2007 8:21 pm Post subject: |
| I agree with Rod. Get the tuning issues worked out and make sure everything fits,works,etc before beating on the 383. |
Posted: Fri Mar 09, 2007 10:26 pm Post subject: |
Yeah, if you're replacing it with a 383 anyway, blow up that 305!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Mar 09, 2007 10:31 pm Post subject: |
| RSFreak wrote: | Yeah, if you're replacing it with a 383 anyway, blow up that 305!  |
I've been trying to get John to do that for a while now! |
Posted: Fri Mar 09, 2007 11:20 pm Post subject: |
Just put a set of smogger heads off a 350 on it and slap the blower on. You'll be down around 7.5 - 8 :1 compression.
DOOO ITTT!!! |
Posted: Sat Mar 10, 2007 12:56 am Post subject: |
Hell, I'll give you my 882 heads just to ride in that thing with the 6-71 strapped to that 305. _________________
