trouble
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Mon Dec 25, 2006 6:20 pm    Post subject: trouble Reply with quote
so im drivin my car to my cousins today for dinner and i noticed at off idel around 2-2500 rpm it was amaking aticking tnoise and got there and checked the oil and stuff it was good then on the way home about halfway back it started doing the noise all the time so i got home and you can hear it really loud its ticking at idle not liek a rod nock but loud ticking and if you reve it up slowly it seems to not get louder with the engine and it still runs and drives fine i put a screw triver on it and listened and you can definateley hear the sound when reving it seems to get a little quieter and thats listening throught the intake throught he valve cover i cant really hear it as wwell ....im thinking its a lifter my oil pressure is fine....im not sure im not as familiar wiht thoese engines as with small import motors
Cadillac of Bellevue
Retail parts sales
vee-six
izcain
9sec Club
PostPosted: Mon Dec 25, 2006 10:07 pm    Post subject: Reply with quote
Sound like you might have some valvetrain problems, You ought to take a peek under those valve covers aqnd see whats going on in there. Maybe a stud has pulled up or something...... Maybe just a loose rocker arm. Were you just driving normal when it happened or were you gettin on it when it started?
9.17 @ 148
PostPosted: Mon Dec 25, 2006 10:16 pm    Post subject: Reply with quote
Same thing happened to my 85 Z28 a few years back. When the ticking started I noticed a performance drop right away and pulled the valve covers immediately. Turned out to be a broken push rod! Damnest thing I ever saw! I've heard of bent push rods before, but this one was broken in two! I had to use a magnet to fish the lower half out of the lifter valley. Shocked
PostPosted: Mon Dec 25, 2006 11:30 pm    Post subject: Reply with quote
I hope its not that extreme.
noises like that can be mistaken for valvetrain noises when there something as simple as a blown exhaust gasket or exhaust leak.
Peek around and let us know!!
might not hurt to pull the valve covers and make sure the valvetrain events are occuring normally and without any problem!
LB985IROC
PostPosted: Tue Dec 26, 2006 8:48 am    Post subject: Reply with quote
well it seems to perform normal and the noise is so damn intermitant like it would only do it at like 2500 rpm wiht no load on the motor then it went away after driving a bit and now it sounds different, really faint but only if you rev the motor
Retail parts sales
vee-six
LB985IROC
PostPosted: Tue Dec 26, 2006 8:49 am    Post subject: Reply with quote
oh ad i did notice i can hear the noise loudest through the water pump.....
Retail parts sales
vee-six
LB985IROC
PostPosted: Tue Dec 26, 2006 9:40 am    Post subject: Reply with quote
so this morning im doing a motor oil flush, oil change wiht royal purple and adding some lucas oil stabilizer
Retail parts sales
vee-six
PostPosted: Tue Dec 26, 2006 1:50 pm    Post subject: Reply with quote
Maybe a bearing inside the water pump? Did the noise go away after the flush?
hmm... Don't Gen II's run off the end of the cam? Does it make it less prone to bearing or impeller failure? Brandon, Paul...Bueller?
Is the temp reading normal?
LB985IROC
PostPosted: Tue Dec 26, 2006 2:14 pm    Post subject: Reply with quote
well the fluhs didnt really help but when i first start the car cold it takes a minute for it to statrt and when you rev the engine it gets a little louder but then starts to fade out as you rev the motor and intermitantley comes on while driving
Retail parts sales
vee-six
LB985IROC
PostPosted: Tue Dec 26, 2006 5:27 pm    Post subject: Reply with quote
well at this point my step dad believes its an exhaust leak...
Retail parts sales
vee-six
PostPosted: Wed Dec 27, 2006 3:00 pm    Post subject: Reply with quote
Headers, or stocker manifolds? If it's headers, then yeah, probably a leak. Manifolds can leak if the bolts back out though.
izcain
9sec Club
PostPosted: Wed Dec 27, 2006 7:56 pm    Post subject: Reply with quote
The manifolds can crack as well. I have seen this happen.
9.17 @ 148
LB985IROC
PostPosted: Thu Dec 28, 2006 11:59 am    Post subject: Reply with quote
well i had a few of the techs at work listen and play with it theyre all sure its a bottom end noise i.e. spun bearing....this sucks so much
Retail parts sales
vee-six
mrpopo573
PostPosted: Thu Dec 28, 2006 3:36 pm    Post subject: Reply with quote
Are we talking about your new z28? I thought the motor was brand new...
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
LB985IROC
PostPosted: Thu Dec 28, 2006 5:10 pm    Post subject: Reply with quote
YEA IT IS......thats why im so pissed about it and the shop that built the motor recently went out of business...im trying to decide my options i spent all my money on the car and now i want to fix it but could i get away with just either having the cranky turned or replacing it and putting in new bearings? or maybe just new bearings<<i doubt it but its worth asking
Retail parts sales
vee-six
PostPosted: Thu Dec 28, 2006 6:06 pm    Post subject: Reply with quote
If it hasnt gone on very long then you very well could get off that easy. You won't know for sure until you pull the pan and take a look. Worst case scenario should be a crank kit and 1 new rod. If its a new engine then it's entirely possible something has come loose. Hopefully it hasnt worn the crank or rod too much yet.
LB985IROC
PostPosted: Thu Dec 28, 2006 7:32 pm    Post subject: Reply with quote
lol just thought id put this in here but my step dad stil swears it has an exhast leak
Retail parts sales
vee-six
PostPosted: Thu Dec 28, 2006 9:09 pm    Post subject: Reply with quote
Just throw a set of gaskets on the manifolds. It's a cheap test to rule that option out.
mrpopo573
PostPosted: Fri Dec 29, 2006 10:14 am    Post subject: Reply with quote
Always nice when the motor builder goes out of business...
Still with a fresh motor I would try to eliminate all external "theories" first.
Like he said, do the manifold gaskets.
Also, I am no motor pro by far, but aren't internal problems always constant noises in the RPM range? As in, they don't have a magical RPM number they only make noise during?
LB985IROC
PostPosted: Fri Dec 29, 2006 10:43 am    Post subject: Reply with quote
IT DOES IT AT AN IDLE LOUDEST IT SEEMS TO FADE OUT SOME ABOVE IDLE AND SEEMS LIEK IT GOES AWAY BUT THE CAR IS LOUD SO IM NOT SURE IF IT GOES AWAY, IT IS DEFINATELY LOUDER WHEN THE CAR IS WARM
Retail parts sales
vee-six
