Leaking injectors
Jess
Administrator
PostPosted: Mon Nov 13, 2006 10:05 am    Post subject: Leaking injectors Reply with quote
Ok, so I had this problem before - only a lot less severe. Last time it was only one injector and it seemed to have fixed itself. Now it seems that all 8 of my injectors are leaking gas onto the manifold - bad enough that it drips onto the pavement. Bashy Bashy So mad I can't see straight So my guess is I have to pull most of the TPI stuff off and put in new O-rings to fix it? Anything I should watch out for when attempting this? Thanks guys...
'88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold
PostPosted: Mon Nov 13, 2006 10:24 am    Post subject: Reply with quote
Just pull them out, and do the o-rings, its not THAT bad, just the normal TPI stuff. Put a little vasaline on the o-rings when you put them in.
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Mon Nov 13, 2006 10:28 am    Post subject: Reply with quote
Just a PITA,
Take your time in cleaning the old gasket material off of the intake and the runners and plenum.
PostPosted: Mon Nov 13, 2006 11:27 am    Post subject: Reply with quote
So the injectors aren't leaking, the fuel rail setup is leaking? It's easy just take your time and remember where the vac lines go.
If you have the 9th injectors, becareful with pivoting it. They like to leak out the back of the fuel rail if moved too much.
PostPosted: Mon Nov 13, 2006 12:04 pm    Post subject: Reply with quote
I had to do the same thing to my engine. Use vasoline on the o-rings and push them in slowly so you don't tear the o-rings. Also make sure you put the injector clips on the rail in correctly.
