AIR pump removal crap!!!!
jakemk8706
PostPosted: Fri Aug 11, 2006 3:20 pm    Post subject: AIR pump removal crap!!!! Reply with quote
so i found all the lines that go to the air pump and it shouldnt be that hard to remove. but now the pickle im in is how is my serpentine belts gonna work. i understand that a smaller belt is requierd but without that pump that wont work. so how do i go about getting rid of the pump...
gas brake dip dip
PostPosted: Fri Aug 11, 2006 3:27 pm    Post subject: Reply with quote
Search on TGO for the belt routing. You change the way you route the belt, and need a smaller one ta-boot.
V8 or V6?
jakemk8706
PostPosted: Fri Aug 11, 2006 5:08 pm    Post subject: Reply with quote
its a 350 TPI
gas brake dip dip
jakemk8706
PostPosted: Fri Aug 11, 2006 5:09 pm    Post subject: Reply with quote
and whats TGO?
gas brake dip dip
PostPosted: Fri Aug 11, 2006 5:12 pm    Post subject: Reply with quote
www.thirdgen.org
PostPosted: Fri Aug 11, 2006 8:03 pm    Post subject: Reply with quote
Jake, I actualy had to use a longer belt. Becuase of the way you have re-route it. IIRC stock was a 94.5" belt, and i had to go to a 96.5" belt.
I don't think I have a picture of the routing I used though.
jakemk8706
PostPosted: Fri Aug 11, 2006 9:02 pm    Post subject: Reply with quote
really. did you use a delete pulley, or just some creative routing?
gas brake dip dip
PostPosted: Fri Aug 11, 2006 9:27 pm    Post subject: Reply with quote
the easy way. = $52.95 + shipping.
http://www.moderndaymuscle.com/inc/sdetail/3509
the "hard" way. = price of a new belt.
PostPosted: Fri Aug 11, 2006 10:09 pm    Post subject: Reply with quote
just diffrent routing, when you take the air pump out, you have to route around the crank, and waterpump diffrently. It will only go one way, it is pretty easy. Just make sure the ribbed side is on the crank pully, and the smooth side is on the water-pump pully.
Make sure everything still turns the same way, and you will be set. It works just fine, no need to spend the money for a delete pully.
PostPosted: Fri Aug 11, 2006 10:47 pm    Post subject: Reply with quote
plus the delete pully adds clutter. a re-route is nice and clean. thats how mine is done. but the prior owner did mine. Smile
jakemk8706
PostPosted: Sat Aug 12, 2006 8:24 am    Post subject: Reply with quote
cool thanks again guys
gas brake dip dip
