A bunch of left over parts, will give away
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Mon Aug 07, 2006 5:51 am    Post subject: A bunch of left over parts, will give away Reply with quote
I have a lot of various interior panels from a 87 z28 I want to get rid of.
Not A full set, they are black plastic, Also:
I have a lot of pieces from the emission system as well. charcoal tank, and valves, also cruise control unit, and lots of other odd and ends.
We stripped the car and can't use this stuff, some are off of a TPI
car and some are off a TBI car. V8
Would like to get rid of more than a few pieces at a time.
thanks
Scott
PostPosted: Mon Aug 07, 2006 10:41 am    Post subject: Reply with quote
if you post a few pictures of your parts pile, or the car with parts on i am sure stuff will start flying off the shelf.
PostPosted: Mon Aug 07, 2006 11:19 am    Post subject: Reply with quote
Hey Scott, do you still have that EGR valve? And how much for the charcoal canister, and associated valves and vacuum lines?
scott in wa.
PostPosted: Mon Aug 07, 2006 11:45 am    Post subject: EGR Reply with quote
Well I wasn't thinking about the EGR, BUT, I guess I could sell it, Send me A pm and make me an offer, not sure where, or if we have the vacuum lines.
As far as all that other stuff you can have it. I will be doing a delete on that canister and routing that line some where else.
I think I read about people doing that on there tpi's
Are there any performance issues with deleting that canister?
Hey maybe we can fit all these interiour plastics into the back of your car???
LOL...
thanks
scott
PostPosted: Mon Aug 07, 2006 6:24 pm    Post subject: Reply with quote
I'd take your cruise control brackets and crap. The birds unit is mounted way up high almost on top of the washer fluid resevoir while the camaros is mounted down on the frame rail under the upper rad house, correct?
PostPosted: Mon Aug 07, 2006 6:33 pm    Post subject: Reply with quote
Yes sir.
