Posted: Sun Aug 06, 2006 3:05 pm Post subject: tourqe spec question |
my hynes manual does not say.
i need tourqe specs for:
2.8L 1986 MPFI
lower intake plenum -to- intake manifold bolts
fuel rail -to-lower intake plenum
upper intake plenum -to- lowr intake plenum
TB -to- upper intake plennum
since these are going into cast aluminum i am thiunking 25LBS sounds good, but if somone has a chiltons manual and could look it up i would be thankfull. |
Posted: Sun Aug 06, 2006 3:58 pm Post subject: |
WTH? My Haynes has those... section 4B-2...
lower intake plenum -to- intake manifold bolts (18 ft lbs)
fuel rail -to-lower intake plenum (18 ft lbs, listed as "fuel rail-to-intake manifold)
upper intake plenum -to- lowr intake plenum (??)
TB -to- upper intake plennum (13 ft lbs) |
Posted: Sun Aug 06, 2006 4:00 pm Post subject: |
hmmm... probably bcause i have a chiltons, not hynes. doh...
thanks man. that helps out alot. i'll assume upper to lower is the same as lower to manifold.  |
Posted: Sun Aug 06, 2006 4:15 pm Post subject: |
| My Haynes manual says a bit different, though it covers all years 1982-1992. The only V6 torque spec it list for me is for the intake manifold (assuming maifold to engine), at 23 ft-lbs. |
Posted: Sun Aug 06, 2006 4:20 pm Post subject: |
Hmm... mine is "Chevrolet Camaro 1982 thru 1992 - All Models" copyright is in '99. Maybe they updated it a few times or something.  |
Posted: Sun Aug 06, 2006 4:27 pm Post subject: |
| Looks like yours is the newer one. I have copyrights listed 1984, 1987, 1989, 1991, 1993. Looks like time to find a newer manual. |
Posted: Mon Aug 07, 2006 10:38 am Post subject: |
| i used to have the chiltons camaro one (i was in a bind and needed a manual, itr was what they had). it had everything. i gave it to chris i think, since he actualy owns a camaro. |
Posted: Mon Aug 07, 2006 11:22 am Post subject: |
Is there actually much of a difference?  |
Posted: Mon Aug 07, 2006 11:45 am Post subject: |
| intirior and body, as well as the placement of alot inb the engine bay. but mechanicle wise, No, there is not. |
Posted: Mon Aug 07, 2006 12:27 pm Post subject: |
| Xophertony wrote: | | i used to have the chiltons camaro one (i was in a bind and needed a manual, itr was what they had). it had everything. i gave it to chris i think, since he actualy owns a camaro. |
No, I stole that from my buddy Justin after he sold his 91 RS. _________________
Posted: Mon Aug 07, 2006 2:07 pm Post subject: |
hmmm... that means i still have the good manual around somwhere. what the hell did i do with it.  |
Posted: Mon Aug 07, 2006 6:29 pm Post subject: |
| Haynes used to be a sweet manual. I've got an old chevelle one, it even has a cross reference listing certain part #s to engine size and hp. If I remember right though haynes was bought by chiltons. Seems like mitchell might even have been in there, but that may just be the time books. |
Posted: Mon Aug 07, 2006 7:42 pm Post subject: |
| "snug" |
Posted: Tue Aug 08, 2006 2:05 am Post subject: |
"just make it tight" was like the motto of our t5 swap. i don't think paul even owns a tourqe wrench  |
Posted: Tue Aug 08, 2006 7:59 am Post subject: |
| Xophertony wrote: | "just make it tight" was like the motto of our t5 swap. i don't think paul even owns a tourqe wrench  |
All you need to torque are Rod bolts, main bolts, head bolts.
And on a 2.8 The lower intake. |
Posted: Tue Aug 08, 2006 8:14 am Post subject: |
And lug nuts.
After I managed to get the lugs on my pickup so insanely tight with an impact once, I started to torque lug nuts. I have 32 lug nuts on the pickup, each one I had to let the compressor build to 140 psi and I could get one broke free. All day project rotating tires.  |
Posted: Tue Aug 08, 2006 2:36 pm Post subject: |
Same thing with my Dad's truck. 32 lugs @ 120 or something ft lbs. Did it all by hand with a breaker bar too.  |
Posted: Tue Aug 08, 2006 3:32 pm Post subject: |
| rjmcgee wrote: | And lug nuts.
LoL I don't think I've ever torque a lug nut.
Hammer needs some finesse!
Fancy Hammer!
Posted: Tue Aug 08, 2006 8:01 pm Post subject: |
| There's alot of things I don't torque.. Just like Paul. If i'm using a star wrench on lugnuts then I don't bother torquing them. But if I'm using an air wrench then I do torque. Main thing with lugs is to get them all even, or you'll warp the rotors. |
That's a mighty fine looking hammer there.
the hammer. |
