Its alive
Goto page 1, 2, 3  Next
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Wed Mar 29, 2006 7:32 am    Post subject: Its alive Reply with quote
Well,
Put a new radiator in it last night, and it started, sounds good, didn't over heat, no leaks, and drove it around the block. Wow the kid got lucky.
Smog pump it making noise, pulls to the right a bit. But she purrs like a kitten.
Was suppose to have a blown motor, but its seems good.
Heater fan doesn't work. Shifts fine.
Wow, I can't believe it.
I told the kid, a Blind squire gets a nut once in a while.
Not very much power compared to the other car, but I bet it doesn't get 8 mpg either. lol.....
It does look like its an Iroc base model with the TBI, probably a 100,00 made but not bad for 1,000.
Seats are very hard; he is going to change them tonight.
PostPosted: Wed Mar 29, 2006 10:16 am    Post subject: Reply with quote
Nice dude.
Now you have all the parts to swap over at leisure. More experiance on the way!
PostPosted: Wed Mar 29, 2006 10:30 am    Post subject: Reply with quote
Or are you going to pick up an f-car, for yourself, and the new motor?
scott in wa.
PostPosted: Wed Mar 29, 2006 10:54 am    Post subject: car Reply with quote
For me???
Maybe I will keep the other car and fix it, swap out motors (back to the 305).
Don’t know yet.
So I have a wiring question.
88 TBI 305 to a TPI, need new harness??? Can I re-pin the tbi to make it tpi? The 87 has the 165 computer and it runs the 8d mask.
We have all the brand new stealth ram intake stuff to swap out the old tpi runners and intake.
Should I stick with MAF??? Or just go straight into speed density??
The motor is built pretty good.
So what should I do? What do you think?
Thanks
Scott
PostPosted: Wed Mar 29, 2006 10:57 am    Post subject: Reply with quote
Depends on what you want to do. If I were you and had the money, I'd pick up the C950 for abour $850. Comes with the computer to tune real time, speed density swap stuff, and harness.
You can't repin the TBI stuff to TPI stuff.
You'll also need to swap fuel pumps in the tank, eliminate the rubber lines that might be at the back of the tank on the outlet side (biggest line at 3/Cool
And change the fuel lines in the engine bay to go to the stealth ram. I used adapters and stainless braided line on mine.
PostPosted: Wed Mar 29, 2006 11:05 am    Post subject: Reply with quote
I'm pretty sure it can be repinned. Might be easier to just swap the whole harness though. Unless you are going to be using the harness still, in the old car.
I would agree with Paul though, if you can swing the money, the C950 is the way to go, especialy with that cammed motor.
PostPosted: Wed Mar 29, 2006 11:07 am    Post subject: Reply with quote
I thought you couldn't repin them because of the way it controls the injectors?
Plus he'd had to splice in the 8 MP injector connectors. No big deal, but hacking a harness kinda sucks.
PostPosted: Wed Mar 29, 2006 11:16 am    Post subject: Reply with quote
you can repin everything, and modify the injector harness. The sensors peices of the harness are re-usable, with a re-pin.
PostPosted: Wed Mar 29, 2006 11:17 am    Post subject: Reply with quote
There's actually a pretty recent thread on tg.o about repinning the 746 ecm to a 730/749 so I don't see why you couldn't pin it to a 165 if you really wanted. Sell the maf/tpi computer/harness to offset the cost of the c950. Smile
Might even find someone on this board that could use the ecm/harness.
PostPosted: Wed Mar 29, 2006 11:21 am    Post subject: Reply with quote
we are talking about repinning a 8746 to a 165.
PostPosted: Wed Mar 29, 2006 11:37 am    Post subject: Reply with quote
He mentioned that lol.
Ya know... I sold my old TPI hardware for $300 on ebay.... add in the cpu and harness and that's a good $500
Get the C950 and be better set!
scott in wa.
PostPosted: Wed Mar 29, 2006 12:21 pm    Post subject: computer Reply with quote
What exactly is a C950 , where do I see it and read about it?
Got a link?
I didn't even think about selling the old harness, for that mater we could sell top end (intake and up) to the new ecm. I have had ZERO issues since adding a new o2 sensor. runs great no alarms. Of cource thats atributed to a few people on this bord, since I knew nothing.
thanks
scott
PostPosted: Wed Mar 29, 2006 12:23 pm    Post subject: Reply with quote
Some basic info can be found here...
http://www.holley.com/950-101.asp
It is basicly Holley's aftermarket EFI management system.
scott in wa.
PostPosted: Wed Mar 29, 2006 12:49 pm    Post subject: Bra. Reply with quote
Thanks for the info.
I got another question,
The front paint is all messed up because they put a bra on it, so I want to go ahead and put another one on there.
what one do I buy? I want the two piece.
I can't seem to find one that says Iroc, or camaro on them.
thanks
scott
PostPosted: Wed Mar 29, 2006 12:52 pm    Post subject: Reply with quote
IIRC, the nose from 85+ is the same.
It might be easier to just paint it. Any new one you get, will need to be painted.
PostPosted: Wed Mar 29, 2006 1:00 pm    Post subject: Reply with quote
WOW, those are only $500... Cool i want one. ...course i don't realy have a the need for it. Sad
PostPosted: Wed Mar 29, 2006 1:01 pm    Post subject: Reply with quote
Its more than that, because you need some other things to go with it. Its about $850 to get everything you need.
scott in wa.
PostPosted: Wed Mar 29, 2006 1:42 pm    Post subject: Reply with quote
"IIRC, the nose from 85+ is the same"
Is this about the bra???
what is IIRC?????
(I am stupid )
PostPosted: Wed Mar 29, 2006 1:45 pm    Post subject: Reply with quote
I meant, IIRC = If I Recall Correctly.
I was speaking about the actual nose body piece on the car.
If you are talking about adding a bra. I think I have one you can have.
PostPosted: Wed Mar 29, 2006 4:36 pm    Post subject: Reply with quote
::jedi mind influence:: you don't want to add a bra. ::/jedi mind influence::
Page 1 of 3
