just wondering about door locks
DyskoChris83
PostPosted: Tue Mar 28, 2006 10:20 am    Post subject: just wondering about door locks Reply with quote
All my locks are broken (was like that when i bought the car) passenger side doesnt work at all, hatch doesnt even have one its just a hole. and the driver u Can use a key but u casn use a dime a small flat rock anything that can turn it. Anyways i was wondering if i could just swap locks and keys out easily, or do i have to have some special fancy locks that will cost me a ton. (And if i dont need fancy ones does anyone have any locks with keys send a tell or whatever) Thanks ( like always excuse my typing im horrible at it.
PostPosted: Tue Mar 28, 2006 10:30 am    Post subject: Reply with quote
Door locks are ~17.99 I think at schmucks. I'm not sure about the hatch ones though.
If you pop off your door panel you'll see a U shaped clip that holds he locks in place, pop the lock rod and pull the clip and the cheap locks slide right out. Smile
PostPosted: Tue Mar 28, 2006 11:50 am    Post subject: Reply with quote
I had the same problem with both my driver and pass door locks, where pretty much any GM door key if wore down enough could open my doors.
A cheaper alternative I found is to go to the junkard, snag a pair of locks off a camaro (along with the hatch lock if its there) take one lock to a locksmith and have them make a key (lots of good locksmiths can do this...) it only cost me like 12 bucks to have them do it.
kurfbird
PostPosted: Tue Mar 28, 2006 12:03 pm    Post subject: Door locks and keys Reply with quote
I have a complete set of door locks and 2 keys
Comes with
hatch
both doors
storage area
2 keys
20.00 plus shipping
They all worked great.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Tue Mar 28, 2006 4:46 pm    Post subject: Reply with quote
Don't know about the hatch, but I pulled a drivers side cylinder out of an '84 Buick and it was an exact match, less the black paint.
DyskoChris83
PostPosted: Tue Mar 28, 2006 7:54 pm    Post subject: Reply with quote
Awesome, i sent a Pm to the guy with the locks. now witht hat only few more minor porblems, ext task besides carb is get my ignition fixed its stuck and u can just push forward and car starts (well would start if car wasnt dead Atm)
