Midnight Sun Member
Posted: Wed Feb 18, 2004 1:22 pm Post subject: |
| Mangus wrote: |
If you do decide to sell it, let me know how much you want for it. I could use a donor car.  |
Eeek... Parting out Jason's car would be a travesty. It may need a little work, but it is still one nice looking GTA. _________________
Laserbeak Member
Joined: 25 Jan 2004 Posts: 25 Location: Mill Creek, WA
Posted: Wed Feb 18, 2004 6:17 pm Post subject: |
Thanks for the kind words Eric.
EDIT: Oops, my bad. I forgot we had a For Sale forum. Check there for info and the asking price.
Jason |
miamivice Member
1982 Pontiac Trans Am
Posted: Wed Feb 18, 2004 6:29 pm Post subject: |
| Mangus wrote: | | miamivice wrote: | | Laserbeak wrote: |
* GODAWFUL fuel consumption for a TPI (out of gas after 120-140 miles |
how much should you be getting? thats what i get. |
I get 23-24 MPG highway and 17-19 street, and thats pretty common for a no-mod or lightly modded TPI 3rd gen.
10 MPG (as you two are reporting) tells me something is seriously wrong... |
well crap
what could be my problem? _________________
Mangus Member
Joined: 10 Jan 2004 Posts: 255 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Mon Feb 23, 2004 10:59 pm Post subject: |
if you have a stock cam, than it could be a couple things (fuel filter, leaking injector, bad fuel pump, bad FPR, etc), most of which would be obvious in that the car wouldn't be running right.
if you have an aftermarket cam, then its probably that. |
Posted: Tue Feb 24, 2004 4:09 am Post subject: |
| i would take mangus up on his offer, hook the scanner up to it, and see what is going on. my guess is somewhere there is a sensor out of whack. |
Posted: Tue Feb 24, 2004 7:49 am Post subject: |
For instance, if the ecm coolant temp sensor goes... it will read much colder than it is, or not read at all, and the computer will put in more fuel thinking its cold, or for saftey cause it doesn't have a reading.
I get 17.8mpg Freeway with no Overdrive. |
Posted: Tue Feb 24, 2004 8:03 am Post subject: |
| my L03 has been known to get 32 on the freeway, with a manual overdrive. |
Slowbird New Member
Joined: 24 Feb 2004 Posts: 11 Location: Hoquiam WA, or OKC OK
Posted: Tue Feb 24, 2004 4:29 pm Post subject: |
Pretty car. A red '89 GTA was almost my first car.....
Good luck selling it. _________________ -Andy
