Tony's complete exhaust system planning thread.
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Sellmanb
PostPosted: Sat Mar 11, 2006 3:10 pm    Post subject: Reply with quote
good job man, nice progress Smile Glad to see your engine is a 350.
Does the catback and cat fit correctly for your routing? I am almost 100% sure it was.
PostPosted: Sat Mar 11, 2006 3:24 pm    Post subject: Reply with quote
Yeah I was able to use some of the slip fits and retain some old hangers and such before welding them solid. Things slide into place pretty well.
PostPosted: Sat Mar 11, 2006 6:02 pm    Post subject: Reply with quote
wow, ok i am finally done. only one accessory bracket could not be re-used. the car feels a little more powerfull now. i had to do major surgery on the plug wires... will be ordering a new set of those tonight.
CONS:
MY STEERING COLUM RUBS THE HEADERS!!!! making you fight to get the flat part past the headers then it jerks in the direction you want to go and you start over again.... NOT GOOD. i need to fix it but havbe no idea what to do. there is pretty much only one way it can go on there. i guess i am just going to hafta drive it like that until we can figure somthing out.
the whole car shudders... ALOT now. (probably from the colum being in constant contact with the headers)
other then that it is pretty cool. in hindsight 3" might be a bit to big... car rasps out on thew way down. stays solid on the way up though.
PostPosted: Sat Mar 11, 2006 6:06 pm    Post subject: Reply with quote
It's not too big. John's 305 with a mild cam had it fine.
I turned the wheel and didn't feel anything. Hmm.
Try unbolting the steering column from the firewall and moving it over. Sometimes there is a good deal of adjustment in there.
Maybe remove that bolt from the steering column shaft and grind down the corner that would hit?
PostPosted: Sat Mar 11, 2006 6:07 pm    Post subject: Reply with quote
You can always bend the pipe a little (not too much) to keep it off contact with the column.....or you could just invest in a different set of headers..... Laughing
(in other news Tony, I got the fuel pump on the fairlane done today..IN 35 MINUTES.....I so rock...so previous request for assistance on that can now be disreguarded.)
PostPosted: Sat Mar 11, 2006 6:24 pm    Post subject: Reply with quote
right on, way to get that engine fire waiteng to happen taken care of.
as for the headers i am going to wait until tomorow to worry about it. i am going to drive it home today, and to the napa for the v6s alternator on monday and i will drive the 6 on tuesday to school. so i have until wednesday to figure out what to do with it before i clearence a primary.
PostPosted: Sat Mar 11, 2006 6:26 pm    Post subject: Reply with quote
cool.
whatever you do, don't cut that bolt on the column.........you'll regret if you ever have to take that thing out and put it back in again.
PostPosted: Sat Mar 11, 2006 6:28 pm    Post subject: Reply with quote
it's the shaft of the colum, not a bolt. but i will keep that in mind. ok i am about to head home from my dads. lets seee how it does on the open road.
I didn't mean cut the whole head off lol. Just round the corner that slides around. If you put a box end wrench on it, it should come off no problem. Provided he doesn't grind too much.
I think moving the column first would be better.
Johnny Iroc's RS did the same thing. That's what we did to make it clear. Could still take it off no problem.
PostPosted: Sat Mar 11, 2006 7:02 pm    Post subject: Reply with quote
oh, i never even saw your other post. so it will move. cool. i'll try that tomorow.
PostPosted: Sat Mar 11, 2006 10:09 pm    Post subject: Reply with quote
well, i can't get the sound file off my cell phone. my windows has been slowly degrading. time to re-install it i think. why is it windows must be periodically re-installed in order to function Rolling Eyes
PostPosted: Sun Mar 12, 2006 2:10 pm    Post subject: Reply with quote
allrighty. i moved the colum and i think i solved the problem. i can't feel it binding anymore, but it does still rub a tiiiiinnnnyyy bit. i figure in about a month the powder coating will have morn off of that spot.
in other news.... i went for a little steering test and figured while i was at it i might as well test my posi... it works Very Happy
PostPosted: Sun Mar 12, 2006 2:14 pm    Post subject: Reply with quote
Burnout Coolness!
So how does she sound now? Any difference?
PostPosted: Sun Mar 12, 2006 8:55 pm    Post subject: Reply with quote
Congrats on getting her together Tony. Get us a sound clip.
PostPosted: Sun Mar 12, 2006 9:40 pm    Post subject: Reply with quote
i need to do some major work on the PC before i can get the soundclip. i think it is about time to re-install windows again.
it sounds like i am running straight pipes. i am realy going to need a pre-muffler or somthing.
also, the car has a problem. it seems like it is missing. under cruise at lets say 55MPH and around 1700 RPM the car will jerk once a second or so... like it has not fired. but there are no afterfires in the exhaust... none of my plug wires are melted.. one of the realy wide rubber boots on one of the 180* plug wires is resting against a header pipe, but it is not melting. and the boot is like a good 3/4ths of an inch thick. it's kinda scaring me. car feels like a piece of junk to drive because of it. do i need to adjust my timing or somthing?
i am ordering new plug wires from summit tonight. probably going to go with the 11.4 MM again. maybe the 8.xMM ones. not sure yet. but i am going to go all 90* bends so i can run them under the headers. then i am going to take the 900* spark plug boot protectors off of my v6 (i have two extra in my parts pile and put them on the V8 so that the wires are even more protected under the primaries.
also, about my vibration increase... would no engine mounts decrease this at all?
PostPosted: Sun Mar 12, 2006 11:54 pm    Post subject: Reply with quote
Straight pipes? With an Aerochamber muffler?
Your ear tuning is way off lol
What vibration?
Sounds like a misfire to me, in terms of the spark going somewhere else.
Makre sure the wires are on all the way. And it's really easy for spark to arc out of the plug wires especially if it's hot. It may have a crack that acts like a conduit.
PostPosted: Mon Mar 13, 2006 12:17 am    Post subject: Reply with quote
hmm... i'll hafta make sure they are all on there real well. i had to cut the 180* boots down considerably to get them to clear the pipes. i am gonna order a set of cut to fit 90* wires. in fact i am going to do that right now....
KH29ROCKS3
PostPosted: Mon Mar 13, 2006 12:09 pm    Post subject: Reply with quote
ya know, there is a reason that they didn't come from the factory that way......I think a good 3" manifold back system would have done ya great. Now with headers, you will forever be under that hood....I promise! Good Luck.
PostPosted: Mon Mar 13, 2006 2:47 pm    Post subject: Reply with quote
Why?
The exhaust manifolds that come with these cars are awful.
I put my headers on over a year ago and have never touched them since. never had a leak and never had to retighten bolts.
PostPosted: Mon Mar 13, 2006 5:30 pm    Post subject: Reply with quote
rjmcgee wrote:
Why?
Same here no touch no leak. Those logs suck balls!
Page 5 of 7
