FS: Automatic Parts for Thirdgen (TH350)
PostPosted: Fri Mar 10, 2006 10:13 am    Post subject: FS: Automatic Parts for Thirdgen (TH350) Reply with quote
All the parts are still in the car but can be removed at anytime.
SOLD $20 - B&M Transmission Cooler with fittings ready to install into your thirdgen.
SOLD $20 - Autometer Transmission Temp Gauge ATM-2640 Electrical Sender. Sender Included.
$50 - B&M Console Mega Shifter With cable and brackets to install. The stick threads are semi striped so the T-Bar handle likes to spin now and then. Just JBweld the sucker on there. The only reason it would need to come off even under installation, is if the stick broke and needed to be replaced.
SOLD $350 TH350 Long Tailshaft. The long tailshaft means put this in your thirdgen and retain your driveshaft (no lengthening or shortening) Originally built by Vancouver Racecar/Transmission builder Jaime Fox. Freshened up my myself this last year. Transgo Stage 2 Shift kit as well as some other Fox made modifications for performance. Shifts nice and firm cruise and rock hard on the go. One small oil leak out of the shifter linkage shaft. Just replace the seal. Pan is tapped for electronic temp sender.
$15 - 153 Tooth 1 piece seal flexplate
$65 - 168 Tooth Gear Reduction starter. Works great.
$30 - 168 Tooth SFI 29.1 2 piece rear flexplate.
Will have a few more parts to come later. Also willing to trade or discount for Manual clutch pedals, Shifter Plate (camaro), boots, etc.
PostPosted: Fri Mar 10, 2006 11:42 am    Post subject: Reply with quote
Does the temp gauge have a fitting to install in the pan?
PostPosted: Fri Mar 10, 2006 12:09 pm    Post subject: Reply with quote
I don't recall that it did. What I ended up doing was getting a drain plug (I think it was for a trans even) from baxter auto.
Pulled the pan, drilled the hole, and welded the bung.
It's on the rear drivers side IIRC where there was plenty of clearance to protrude into the pan.
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Fri Mar 10, 2006 12:26 pm    Post subject: Twilightoptics Reply with quote
Twilightoptics,
are you switching to a manual tranni?
whatcha doin???
thanks
scott
budgetracer
PostPosted: Fri Mar 10, 2006 6:15 pm    Post subject: Reply with quote
Check your PMs Smile
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Mon Mar 13, 2006 3:17 am    Post subject: Reply with quote
console megashifter is for the 3rd gens right???
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Mon Mar 13, 2006 10:09 am    Post subject: Reply with quote
IIRC it will run in anything but an 88+ Formula.
LB985IROC
PostPosted: Mon Mar 13, 2006 12:42 pm    Post subject: Reply with quote
ok well then i want it lol i want one so bad
Retail parts sales
vee-six
LB985IROC
PostPosted: Tue Mar 14, 2006 6:20 pm    Post subject: Reply with quote
so yea umm let me know what u wanna do not sur ehow far vancouver is form here
Retail parts sales
vee-six
PostPosted: Tue Mar 14, 2006 10:58 pm    Post subject: Reply with quote
does a different shifter do anything for you? or do they just look cool (and the do look cool)
PostPosted: Tue Mar 14, 2006 10:59 pm    Post subject: Reply with quote
It's a little bit of a drive, yeah. Vancouver is just North of Portland OR, but on our side of the border.
LB985IROC
PostPosted: Wed Mar 15, 2006 12:00 am    Post subject: Reply with quote
well it does look cool but i want the rachet more then anything lol
Retail parts sales
vee-six
PostPosted: Wed Mar 15, 2006 10:57 am    Post subject: Reply with quote
Will talk to ya about it when I get back from Bend saturday.
LB985IROC
PostPosted: Wed Mar 15, 2006 2:14 pm    Post subject: Reply with quote
works for me
Retail parts sales
vee-six
