vega_guy_76 Member
Joined: 02 Jan 2005 Posts: 79 Location: St Helens, OR
Posted: Tue Feb 07, 2006 8:18 pm Post subject: |
I still think you're wrong. Care to explain some more? Maybe links or photo's?
Charlie |
Posted: Tue Feb 07, 2006 8:21 pm Post subject: |
| Threw in an edit there.. Do you hang around on any non chevy forums much? You'll find it a pet peeve of the non chevy forums to have their engines called bb's. |
vega_guy_76 Member
Posted: Tue Feb 07, 2006 8:25 pm Post subject: |
You must definately be thinking of the Pontiac blocks. Because Buick 350 (small block) heads will not fit the larger 400,430,455 big blocks. And yes, I do hang around http://www.v8buick.com/index.php? If you scroll down you'll see they have under "Engine Tech" | Quote: | Small block tech (4 Viewing)
Curioius about the little brother? Ask here how to get your 215/300/340/350 some respect! |
and | Quote: | Race 400/430/455 (6 Viewing)
The who, what, where, and how of screamin' race big blocks. |
and | Quote: | Street/strip 400/430/455 (6 Viewing)
Building your GS motor? Ask all questions relating to the late big block here. |
Charlie |
vega_guy_76 Member
Posted: Tue Feb 07, 2006 8:33 pm Post subject: |
Here is another website that states the differences. http://en.wikipedia.org/wiki/Buick_V8_engine#Buick_.22Big-Block.22
| Quote: | | The 455.72 in³ (7.5 L) 455 Buick V8 used a 4.312 in bore and 3.90 in stroke. Most parts except the pistons interchange with the 400 and 430. |
| Quote: | | The Buick 350 V8 had a 3.80 in bore (like the 3800) and retained the 3.85 in stroke of the 340. |
I'm still searching for deck height and bore spacing measurements.
Charlie |
Posted: Tue Feb 07, 2006 8:36 pm Post subject: |
Just doin some searchin.. not finding anything buick specific either..
You do find alot of people callin pontiacs and olds bb and sb too. Both of which I know for sure dont have bb and sb's. I am seing the listing of the 2 different series of buick engines too.
Just saw one buick site.. buick prototype motor.. 550hp and 750ft/lbs.. stock. Didnt build it cause the th400 wouldnt hold up.
Always thought a buick 455 might be fun.. they're hte largest bore shortest stroke 455 of the bunch. |
Posted: Tue Feb 07, 2006 8:42 pm Post subject: |
Whorin it up now.
Found a site with interesting buick trivia. Says here that the original engine for the Shelby Cobra was going to be a buick. Talk about a weird combination. Buick powered mustangs.
LMAO! looks like you can trust Summit catalog for tech data too. I just tried checking camshafts for buicks.. and end up with a 307 olds?? lol. Didnt know the 307 olds was a buick.
Anyway, I thought the 2 different sizes were more an engine series thing. But I'm not finding that on the web. Show different part #s for the smaller cams and the 400cid ups.. So looks like you could be right. Not what i've seen before though. But that info may have come from olds/pontiac oriented guys as well.
Point to Charlie.....
Hard to imagine a bb that weighs in only 60lbs heavier then a sb chevy in any case. With the right build and a few sandbags that sprint oughta do wheelies. |
Posted: Tue Feb 07, 2006 9:00 pm Post subject: |
| vega_guy_76 wrote: | | rjmcgee wrote: | Thats a big stable to only house 200 ponies.  |
The engine came from a '70 Riviera and had 370hp 510ft-lbs. It was good enough for 14.64@96mph at PIR almost a year ago with 2.56 gears.
Charlie |
Looks like a 2 barrel on there. |
vega_guy_76 Member
Posted: Tue Feb 07, 2006 9:01 pm Post subject: |
A Buick powered Mustang... that's something the Mustang guys may not wanna know. lol
I found the following here a little over half way down the page under orange text of "Buick V8 Engine": http://www.absoluteastronomy.com/reference/buick_v8_engine
| Quote: | | The 215 V8 was developed first, spawning the 3800 V6. Then the 3800 design was used to create the 300. Both had the same 4.24 in (107.7 mm) bore spacing and the 3800 and 300 shared the same 3.75 in (95.2 mm) by 3.40 in (86.4 mm) bore and stroke dimensions. |
| Quote: | The Buick 350 V8 had a 3.80 in bore (like the 3800 (3800: the 3800 family is a large v6 engine used by general motors....
Another source: http://www.v8buick.com/showthread.php?t=57806&highlight=buick+455+bore+spacing
Scroll down to the second post which is by Alan.
| Quote: | | a stock 455 has 4.750 bore spacing. |
Charlie |
Posted: Tue Feb 07, 2006 9:05 pm Post subject: |
I found this too.
Notice that "small block" and "big block" are in quotes even? I think we're not the first 2 to debate this! Anyway, whatever the difference there are 2 different modern v/8 lines in the buick family.
I may have even been thinkin about the 2nd generation nailheads. Notice they go from 364cid up to bb type displacement too. |
vega_guy_76 Member
Posted: Tue Feb 07, 2006 9:12 pm Post subject: |
| rjmcgee wrote: | | Looks like a 2 barrel on there. |
It's an illusion. Drop base air cleaner to an Edelbrock 750cfm square-bore carb to a square-bore to spread-bore adapter on the stock spread-bore intake.
Charlie |
84transam383 Banned
Posted: Tue Feb 07, 2006 11:16 pm Post subject: |
oh yeah well...i blew up the rearend when i owned it..
oh yah btw rodney,that land yacht weighs in at 4500+
mid 14s anything weighing that much with a 2.56 pegleg rear on skinny street radials is pretty impressive in my book.
i blew the rearend doin a burnout into drive somewhere near redline lmao
i think charlie was there when the damn wheel,axle,brake drum fell out the car lmao |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed Feb 08, 2006 11:32 am Post subject: |
Nice Monza, or second gen Vega
Both my older brothers put V-6's in their Vegas, great cars.
You see the prices for the Cosworths now WOW. |
vega_guy_76 Member
Posted: Wed Feb 08, 2006 9:05 pm Post subject: |
| 84transam383 wrote: | oh yah btw rodney,that land yacht weighs in at 4500+
mid 14s anything weighing that much with a 2.56 pegleg rear on skinny street radials is pretty impressive in my book. |
Actually it weighs 4100lbs with me in it, but close enough. lol That last comment reminds me of when I unintentionally did the 1/8th mile burnout at PIR with it. I stood on the throttle on the green and kept thinking "it's gonna hook. it's gonna hook." It finally hooked by the time I made it to the overpass.
Charlie |
