Posted: Mon Dec 12, 2005 8:27 am Post subject: A quick teaser pic of my weekend. |
Pauly and I got some work done on the camaro this weekend.
Quick teaser pic ... (from my crappy cell-phone camara.)
And here is one of Hardcore, working on those pesky a-arms.
Sellmanb Member
Posted: Mon Dec 12, 2005 9:07 am Post subject: |
| sick wheels! |
Posted: Mon Dec 12, 2005 9:15 pm Post subject: |
Umm.. whats with the 6ft of clearance above the tire??  |
Posted: Mon Dec 12, 2005 9:16 pm Post subject: |
I wanna see the slam!
Posted: Mon Dec 12, 2005 10:07 pm Post subject: |
| You doing those weight jacks finally? |
Posted: Mon Dec 12, 2005 11:06 pm Post subject: |
| iansane wrote: | | You doing those weight jacks finally? |
Yup.
I would have had pictures up tonight, but had a slight bit of trouble, with the *cough* missing...ummmm, USB cable for the camera. |
Posted: Tue Dec 13, 2005 1:00 am Post subject: |
| chevymad wrote: | Umm.. whats with the 6ft of clearance above the tire??  |
Still on jack stands  |
Posted: Tue Dec 13, 2005 1:13 am Post subject: |
Are you going to be setting the height near the same? What's the spring rate compared to your current setup? _________________
Posted: Tue Dec 13, 2005 7:07 am Post subject: |
| Right now it is down real low, seems to be doing fine there. Spring rates are 750# front 175# rear. I wouldn't mind a little stiffer, at some point I'm probably going to go to 800 or 825, and I want to put on the UE panhard brackets, if I do that, I'll probably be in the 300# rear range. |
Posted: Tue Dec 13, 2005 8:07 pm Post subject: |
And here are better pics. (execpt its freakin dark when I leave for work, and dark when I get home, so the pictures were taken in the dark)
Posted: Tue Dec 13, 2005 8:21 pm Post subject: |
Need some parking lot photos from a little bit farther back.  |
Posted: Tue Dec 13, 2005 8:41 pm Post subject: |
Wow!
I agree we need better pics but from what I can see... fricking sweet!
What a difference. Congrats Dewey... it looks good AND you completed a project
Posted: Tue Dec 13, 2005 8:44 pm Post subject: |
| Looks sweet. Does it handle better? |
Posted: Tue Dec 13, 2005 8:46 pm Post subject: |
| Yeah, it does, not sure how much was the tires, and how much was the spring rates. I still have a few minor kinks to work out, like the rear-bump stops, and such. And I probably should get it aligned, once I find the final height setting. |
CheezX Member
Posted: Wed Dec 14, 2005 4:57 pm Post subject: |
Are the shocks holding it up in those pictures? I thought you said it was lower than mine.
I gotta take a picture of my bumpstop for you. hehe |
Posted: Wed Dec 14, 2005 5:03 pm Post subject: |
Those are bad angles to show it...
And I was going to chat with you about bump stops. I think I have a solution for the rears, but was going to see what you did in the front. |
