NEW, gauge questions
DyskoChris83
PostPosted: Fri Nov 18, 2005 1:58 am    Post subject: NEW, gauge questions Reply with quote
like a year ago i got my 305 rebuilt and the mechanic im guessing was bad because 3 of my gauge didnt work (oil pressure, temp, and battery volts) they didnt work when i got it back. I found out he used old spark plugs etc. this is reason for thinking he did a bad job. Well now my tach doesnt work. any ideas about how i can go and fix this or would it be easier to take it to a shop? any help would be appreciated. thanks - Chris
PostPosted: Fri Nov 18, 2005 12:15 pm    Post subject: Reply with quote
Fixing anything on these cars is easy. Just takes a little patience to learn and some determination.
What kind of car? Year?
The oil pressure gauge runs on one wire from a sending unit on the engine block.
Same with coolant.
Not sure about battery volts.
The Tach runs off a WHITE (usually cream color after the years) wire from the distributor. It could be that wire, or something in your dash all together.
Yeah, old spark plugs is pretty shitty. Where'd you take it so I know not to go there?!
DyskoChris83
PostPosted: Fri Nov 18, 2005 2:38 pm    Post subject: Reply with quote
oops forgot to add car stuff sorry, its an 83 camaro with a 305. yeah i might take it a shop and ask them, thanks for the help i plan on tearing my dash apart this weekend. maybe loose wires or soemthing simple (prays).
DyskoChris83
PostPosted: Fri Nov 18, 2005 2:39 pm    Post subject: Reply with quote
i bought the car at this used car lot and they had a mechanic there but they went out of busines so dont worry about that mechanic.
AKMark
New Member
PostPosted: Fri Dec 02, 2005 1:01 am    Post subject: Volt gauge Reply with quote
Actually the volt gauge shouldn't die. On my 3rd gen (86), it's actually run from the power buss that feeds the dash panel. There is no specific wire that supports the volt gauge.
I'm in the process of changing my idiot lights to gauges, and so far no real challenges. If you are near PDX, I'd be glad to help.
86 Camaro, L34, 700R4, 2.73 and T-top. So far it's all original.
89 Firebird 2.8, 5 speed t-top, won't start!
