Cascade Crew Message Forums
charlie6178 Member
Posted: Tue Dec 20, 2016 9:03 am Post subject: Intake idea |
So last summer after I ran out of other projects, I finally finished up my I guess you could call it "restoration" on my 92 1LE Z28. I had a blast cruising it around for the summer, and now I am looking to do some bolt on power. The car has headers on it, 3.73's, a 2800 stall converter, and drag radials. Other than that it's a stock old L98. It runs high 13.80's, low 13.90's all day, and will pull a 1.79 60' pretty consistent. I want to do some crazy cutting and welding, and mold both an L98, and LT1 intake manifold together, and basically make a bolt on LT1 intake with a front water crossover, and utilize the factory rails and line placement of the L98. I'm a machinist, and do these type of off the wall parts for all kinds of cars, all the time. Does anybody happen to have a whole TPI setup laying around they would let go of locally? I have complete LT1 to cut on, now I just need an L98 manifold to play with / canabilize! _________________ 1992 Camaro 1LE Z28 |
Posted: Tue Dec 20, 2016 9:20 am Post subject: |
| That is an interesting way to go about it, I thought the LT1 manifold basically bolted on if you machine the distributor hole. |
charlie6178 Member
Posted: Tue Dec 20, 2016 9:36 am Post subject: |
It does, but you have to modify the fuel lines, or do AN adapters, as well as a remote thermostat and tap the intake for water at the front of the heads. I want to make it functionally like the TPIS mini ram, without spending a couple grand at TPIS. and I want to utilize the TPI rails and lines so it will be a direct bolt on without hacking at the fuel lines on the car. It's going to take a ton of welding an machine work to do it, but I am 100% confident I can make something that will work as well as the TPIS mini ram, or the McFarland short ram, and direct plug and play, and look like the car came that way. That and a set of ported 113's, with a good tune, and I think it will change the way the car pulls up top dramatically. _________________ 1992 Camaro 1LE Z28 |
Posted: Tue Dec 20, 2016 10:32 am Post subject: |
| If you are doing all that, I would slap a cam in as well to take advantage of the higher RPM flow. |
charlie6178 Member
Posted: Tue Dec 20, 2016 11:18 am Post subject: |
well I'm not going for huge horsepower by any means. I still want a stock camshaft sound. The heads I am working on are going to be focused on air speed Than volume, and a bunch of unshrouding and chamber work. I am going to do 1.65 comp steel rocker arms to get the lift up a bit. I want to keep the car looking, sounding, and driving, as factory appearing as possible. My main goal really is to just get rid of the thing falling on its face at high rpm with the stock TPI intake. It hooks and digs just fine down low, then as soon as it shifts to third it just runs out of beans on the drag strip lol I did some Wednesday night ET brackets last season with my 4th gen, and had a ton of fun after not racing for the last 7 years. I am just aiming at making the most out of a "max effort bolt ons" stock L98.
So if anybody has a tuned port intake / fuel rail / throttle body setup laying around they want to go away cheap, I'd love to get started on this project! _________________ 1992 Camaro 1LE Z28 |
