G33K5QU4D Member
Joined: 23 Feb 2014 Posts: 26 Location: Hillsboro, Oregon
1983 Chevrolet Camaro
Posted: Wed Jun 04, 2014 6:06 pm Post subject: Help Passing DEQ |
Hey guys,
So my problem is that my 83 fails DEQ both times I've taken it in. The hydrocarbons or whatever are reading into the 3000's, when it says it can only be 220. Took it to a shop, said it was going to be $2000 to replace the catalytic converter, we were like nope, lowered the idle, and somehow it did way worse, reading in the 4000's. Anyone have any idea on how to fix this? _________________
1983 Camaro |
Posted: Wed Jun 04, 2014 6:27 pm Post subject: |
check your timing
make sure it has no faulty ignition parts
bad cat
check your compression |
Posted: Wed Jun 04, 2014 6:47 pm Post subject: |
If you want to fix it a new Magnaflow cat is like $80, but you might want to figure out if something else took the cat out.
If you just want to pass you want a high idle, very retarded ignition timing, a very hot engine, and as much isopropyl as the thing will take without stalling. |
Posted: Wed Jun 04, 2014 8:37 pm Post subject: |
$2,000.00 to replace a catalytic converter is insane. I hope that was a typo. I had this job done once and it was 200.
I have a catalytic converter from my 86 firebird that has about 50,000 miles on it. I would be willing to let it go cheap. Should be less than $100 to have it installed by an exhaust shop. Especially if we cut your old one off first.
You will need to figure out why the old one failed, or else the new one will too. |
G33K5QU4D Member
Posted: Wed Jun 04, 2014 9:19 pm Post subject: |
They wanted to replace a bunch of other things as well, but I figured 2000 just to pass emissions was way too much. They said something about the carb leaking fuel, although I hadn't seen that happen. It feels and sounds like it's running fine, though. _________________
1983 Camaro |
Posted: Thu Jun 05, 2014 6:52 am Post subject: |
| G33K5QU4D wrote: | | carb leaking fuel |
Please tell me you are not still running the Rochester sequential 2-barrel on there.
If so I think I may have figured out your problem.  |
G33K5QU4D Member
Posted: Thu Jun 05, 2014 7:22 am Post subject: |
I have the original carb in there, by the sound of it, those tend to fail? What should I get to replace it? _________________
1983 Camaro |
Posted: Thu Jun 05, 2014 8:19 am Post subject: |
MPFI
I kid, I am out of my element here. |
G33K5QU4D Member
Posted: Thu Jun 05, 2014 8:32 am Post subject: |
As ideal as that would be,I haven't the slightest clue as to how to convert, and it would probably be outside of my budget haha. I would be interested in picking up your cat, though, just to see if that makes a difference. _________________
1983 Camaro |
Posted: Thu Jun 05, 2014 10:36 am Post subject: |
| I can cut it off this evening after work. if you want to swing by I have a garage full of parts right now, you might see something else you want/need. I have the most comfortable seats you will ever sit in, you have to give them a test sit. |
G33K5QU4D Member
Posted: Thu Jun 05, 2014 10:53 am Post subject: |
That would be awesome, if you wanna pm me your address I can swing by later. _________________
1983 Camaro |
G33K5QU4D Member
Posted: Sun Jun 15, 2014 7:37 pm Post subject: |
UPDATE: Got the new cat on (Thanks for it btw), swapped out the carb, changed the oil, ect, my tester says it's looking pretty good, gonna take it to DEQ this week, hopefully it passes, as this will be my fourth attempt lol. _________________
1983 Camaro |
BluFbdy Member
Posted: Mon Jun 16, 2014 3:07 pm Post subject: |
If it fails, isopropyl alchohol would do the trip as mentioned before, always passed the sniffer in az with that, never had a core in my catalytic converter but the alchohol made up the difference _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Mon Jun 16, 2014 9:20 pm Post subject: |
Right on. I still have those seats too  |
G33K5QU4D Member
Posted: Sat Jun 21, 2014 9:34 pm Post subject: |
UPDATE AGAIN: shop said like 2 cylinders weren't firing at all, which I guess explains the high hydrocarbons. Not sure the cause of that problem yet, shop still working on it. Once that gets fixed, I'd be down to check out those seats again and that one bar if that's still available. _________________
1983 Camaro |
G33K5QU4D Member
Posted: Wed Jun 25, 2014 6:06 pm Post subject: |
OK, shop fixed ignition timing and all that jazz, but still has slightly too high hydrocarbons. The hydrocarbons go up when doing the throttle test for some reason. Also it has high CO2. I was gonna call the shop back up and say it didn't pass, but I am at a loss as to what is causing it to fail still. I took it twice today.
I might just give the alcohol thing a shot and see how that works. _________________
1983 Camaro |
Posted: Wed Jun 25, 2014 6:47 pm Post subject: |
| If I remember correctly, oregon makes you pass a higher standard today then the car was originally designed for. Basically they want them off the road. Didn't Dewey try like 40x before passing? I'd load the thing with alcohol and give it a go. |
Posted: Thu Jun 26, 2014 6:21 am Post subject: |
Use race grade methanol. About a 1:5 ratio. Or Drill a 5/16 hole 4-5" infront of your cat from the driver side. _________________ A redline a day keeps the carbon away! |
Posted: Thu Jun 26, 2014 9:23 am Post subject: |
| Could yo drill that hole in the blocked off air injection pipe paul? His can has a blocked off air injection hole. |
G33K5QU4D Member
Posted: Thu Jun 26, 2014 10:41 am Post subject: |
Taking it back to the shop today. Failed a third time after I got it back. _________________
1983 Camaro |
