Brake lines
jchaussee
PostPosted: Fri Dec 13, 2013 11:32 am    Post subject: Brake lines Reply with quote
I am going to redo brake lines eventually on my camaro amd was curious if it is ok to replace thr coils and squiggly lines with flex. Mine loik like a 5 year old put them in.
PostPosted: Fri Dec 13, 2013 1:54 pm    Post subject: Reply with quote
Coils are there for a reason.
PostPosted: Fri Dec 13, 2013 5:01 pm    Post subject: Reply with quote
Not challenging you, genuinely curious, what is that reason?
PostPosted: Fri Dec 13, 2013 5:08 pm    Post subject: Reply with quote
Vibration, mild bit of flexibility from chassis movement without stressing the line, and cooling.
PostPosted: Fri Dec 13, 2013 5:14 pm    Post subject: Reply with quote
"Cooling" right next to the exhaust manifold. Wink
It's a holdover from GM's body-on-frame days, but probably not a bad idea considering the ungodly amount of chassis and firewall flex in a thirdgen.
jchaussee
PostPosted: Fri Dec 13, 2013 5:33 pm    Post subject: Reply with quote
Ya. None of the new cars have it . I was thinking flex from the hard lines to master. Most of mine have been straigjtened out from someine
PostPosted: Fri Dec 13, 2013 6:35 pm    Post subject: Reply with quote
"Flex" lines do just that, they flex. The more soft lines you add, the squishier your pedal will become.
PostPosted: Fri Dec 13, 2013 6:57 pm    Post subject: Reply with quote
Just put a couple spirals or some sort of anti-fatigue bends in the new lines with a tubing bender. No biggy.
Or, if you want to keep the factory proportioning valve just go to the yard and get some factory lines.
No reason to reinvent the wheel here. Just my two cents.
jchaussee
PostPosted: Fri Dec 13, 2013 9:23 pm    Post subject: Reply with quote
If I am runninh the 99 rear, isnt it best to get an adjustable prop valve? ,as far as lines I will prob just re spiral mine to make look better,. Rigjt now it looks like sagetti
PostPosted: Sun Dec 15, 2013 9:13 am    Post subject: Reply with quote
I am running a braided steel flex line on mine. My pedal is squishy. Sad
PostPosted: Sun Dec 15, 2013 11:05 am    Post subject: Reply with quote
Tony the braided has less flex. My guess air is trapped somewhere out the master is bypassing. Old contaminated fluid will do it too.
