BluFbdy Member
Posted: Tue Sep 24, 2013 9:01 pm Post subject: Why not add another smoking thread?? |
Alright so I've done some extensive research into this subject....(roughly 10 mins of googling) and I've found some conflicting info on which valve stem seals to use. Intake, the common answer is the positive type seal, now for exhaust I've been seeing a lot of people using another intake positive seal on those because its a true seal, however they all note that they don't withstand heat as well, and some reference the fel pro high temp option which is an umbrella type, can take the heat but doesnt seal as well...
So what would you guys do? The camaro is undergoing a makeover at my buddy's shop currently but as soon as its cured I'm going to tear into the valve stem seals, I just want what's going to stop my smoking problem and last properly.
Any info on this subject?? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Tue Sep 24, 2013 9:04 pm Post subject: |
Btw here's a teaser of the current work, you may notice something missing, or not if I did the job properly (which I actually pulled off for once) _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Sep 24, 2013 9:32 pm Post subject: |
Good Viton Positive seals on all. _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Tue Sep 24, 2013 9:33 pm Post subject: |
Viton being the material correct? Got a p/n by chance? And I also read some using the o rings and some not....soooo yes / no to the o rings? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Sep 24, 2013 9:42 pm Post subject: |
The car stereo guy with a shaved antenna? |
Orings and umbrella seals are 50-60s technology. Viton is the material. The catch with positive seals is that the guides have to be cut down to accept them . No part number. You get the seal that matches your guide cut dia and valve stem dia. Felpro from summit should do right. _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Tue Sep 24, 2013 9:47 pm Post subject: |
Agggh so I have to tear it down do some measurements then order them? Blarg lol
And yes Aaron I shaved the antenna lol never listen to the radio any way, subs doesn't like the static much. That and after 13 hours of straight work on the car I got a little stupid, one thing led to another, the antenna smacked me in the neck/face and I decided to get rid of it to put it in its place or something _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Tue Sep 24, 2013 10:29 pm Post subject: |
Sealed Power MV-1888 - Sealed Power Valve Stem Seals
Valve Stem Seal, OEM Design, Each
There's a blurb from summits mobile site, they have oem seals made with Viton I guess, gotta love search filters lol will those work? The heads aren't machined at all except for the studs being tapped out for threaded studs _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Sep 25, 2013 10:47 am Post subject: |
I got rid of my antenna when I did my paintjob too. It's one of my favorite mods. I replaced it with an amplified FM antenna under my dash pad; it gets better reception than some of my other vehicles now! _________________ 84 Camaro Z28 - LS1/T56
BluFbdy Member
Posted: Wed Sep 25, 2013 3:18 pm Post subject: |
I'm just all around anti am/fm radio, for one it gets way too static up here, and two they repeat songs over and over until you can't stand them anymore lol
Paul got any advice on the part I posted last night? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
91camaro_rs Member
Posted: Thu Sep 26, 2013 1:24 pm Post subject: |
i can get the fel pro and sealed power ones from work, they have a high heat exhaust option that has rubber on it as opposed to normal heat are just plastic, and intake are viton.
andy let me know what you get cause i need em too _________________
Posted: Thu Sep 26, 2013 4:54 pm Post subject: |
The guide holding material of the head casting must be cut down or they wont work. Period.
You want FLEX kind.
Stay way away from these.
Stock O-Ring = Bad
See how fat the casting from the guide is? That area needs to be cut to your seal size - usually 0.500". Also, if it's not cut down enough the valve retainer will contact it depending on your cam/lift/rocker combo. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Mon Sep 30, 2013 4:34 pm Post subject: |
.5" seems like a lot, i have those flex ones in fel pro at work _________________
Posted: Mon Sep 30, 2013 4:50 pm Post subject: |
What do you mean it seems like a lot? Most valve stems are 11/32" and the guide cut down for the seal is 0.5".
You guys also need to keep in mine, if you're burning that much oil, there's a good chance the GUIDE itself is reamed too large causing the valve to move too much and allow more oil down/wear out the seal faster.
Intake seals are really the most important as the oil gets into the chamber from them only. Exhaust seals just make for a messy exhaust outlet. _________________ A redline a day keeps the carbon away! |
Posted: Tue Oct 01, 2013 8:59 am Post subject: |
For what its worth on an 87 LG4 we had years ago the guides were already machined for positive seals, but they werent installed from the factory. |
91camaro_rs Member
Posted: Tue Oct 01, 2013 9:28 am Post subject: |
Ok so the guide is just the part of the head that the valve slides through? What do you use to machine it _________________
Posted: Tue Oct 01, 2013 10:31 am Post subject: |
Specialized cutter for cutting the guide and the casting for the seal. Perferably in a mill. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Tue Oct 01, 2013 2:15 pm Post subject: |
I just called bowtie performance and they saidnwith the heads I have they should already be set for the positive seals _________________
