Sellmanb Member
Posted: Wed Aug 10, 2005 10:00 pm Post subject: Stupidest question of the fiscal year :) |
Which end is up... on a water pump.
Does the weep hole face upwards, or downwards?
Reason I ask is because every time I have started up my car, even after new intake gaskets I seemed to have produced coolant coming from the bolt holes... only after this one I made sure to RTV EVERYTHING including the bolts and bolt holes.... so i was looking around, and it seems to be coming more from the thermostat area... when I saw the weep hole and never did really think about which side went up. I've got a heater hose coming from one end, and lower radiator from the other... not sure if they're the same sized hose fittings or not though.
I'm sure I have it on right, but would like to double check  |
Posted: Wed Aug 10, 2005 10:25 pm Post subject: |
Weep hole down. So gravity can help the pump weep. |
JohnnyIROC-Z Member
Joined: 14 Jan 2004 Posts: 204 Location: Washougal, WA
1995 Pontiac Formula
Posted: Thu Aug 11, 2005 2:13 pm Post subject: |
| Also just a hint, You'd never get it on if it was on upside down. the bolt holes wouldn't have lined up and you would for sure know it! |
Sellmanb Member
Posted: Fri Aug 12, 2005 7:43 pm Post subject: |
| JohnnyIROC-Z wrote: | | Also just a hint, You'd never get it on if it was on upside down. the bolt holes wouldn't have lined up and you would for sure know it! |
ACTUALLY....
lmao, I guess I'm going to be doing a little jingle with my water pump on my next day off lol.
Want to see a picture of a waterpump put on upside down? Cuz I can sure take a picture of it...
no wonder I get a massive coolant leak from the thermostat housing when I start the car, eh? hah. |
