jchaussee Member
Posted: Mon May 27, 2013 11:23 am Post subject: Have to complete by Dec Project thread |
so I figured I would put all my threads into one. My goal is to make it as nice as I can on my small budget. I have decided that I am going to do a full rebuild. I suffered a minor heart attack on thurs and dr said I need to do something that helps me destress and calm down. I enjoy working on my car. So far for enginfe I have my perfromer rpm intake, have a qjet built to old school edlebrock specs, and my 1.94/1.50 +7cc combistion and 167 intake runner heads . I am looking at pistons and rods. Many xhoices. So I guess we will start iff how do I figure out what to get and is it better to get a rebuid kit that includes all. |
Posted: Mon May 27, 2013 11:45 am Post subject: |
This conversation is better had with your machinist. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Mon May 27, 2013 11:52 am Post subject: |
I thought that that may be the case. I have just been browsing.cl. Also is there anyway just by apperence or size.tobgive a ballpark stall on my.torgie converter. |
Posted: Mon May 27, 2013 12:12 pm Post subject: |
No way to look at a convertor and tell what stall it is. Stall actually changes depending on weight, gearing and hp of your car as well. So the same convertor will stall to different speeds with each of those variables. |
jchaussee Member
Posted: Mon May 27, 2013 2:41 pm Post subject: |
Ok. Thats what i figured. the machine.shop guy was asking.me.about stall.i will jist ask his recomendation and get at the end. I just want to make sure all parts matxh to get maximun benifit |
Posted: Mon May 27, 2013 3:04 pm Post subject: |
Build the motor you want, then match the drivetrain. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Mon May 27, 2013 4:54 pm Post subject: |
Cool. Because the only tbing I am stuck.on keepinf is the rear I got. Tranny is 700r4 butbwho knows how long it will last. I am also thinking of replumbing my fuel and brake lines. But that will b later. I have to still strip down the block and get into machine shop. What usually is needed to be done at the maxhine shop to the block. ? |
Posted: Mon May 27, 2013 5:34 pm Post subject: |
Machinist needs to look at it and find out how nice you want it. Aka how big your wallet is. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Mon May 27, 2013 5:44 pm Post subject: |
Lol. so basically a clean and check in my case. My headwork which.is cleaning, surgacing, leak test, spring and valve check and maybe a gew other little tbings' is running me 184. Are these heads worth doing any other work to.? What about gasket match . Some people say yes, some say no. that is something I can actually do on my own. |
Posted: Mon May 27, 2013 7:24 pm Post subject: |
That sounds like a potentially serious health issue. I hope it doesn't progress any further than that! Good thing you can find your happy place in your car. |
jchaussee Member
Posted: Mon May 27, 2013 8:49 pm Post subject: |
Heart diaease runs rampant in family. though if i have, ill know.more this werk, ill be youngest so far. or I just have been overly stressed and it caught up with me. Eother way my heart has always been bad |
Posted: Tue May 28, 2013 6:54 am Post subject: |
Wait, I'm very confused.
Wasn't this engine pulled due to a slow compression-into-coolant leak? Now we're buying new rods?
When you pulled the heads was there a gasket failure?
You said in the other thread that the walls were "smooth." Do you mean that they're glazed or what? Did it have blowby? Go through oil?
Seems to me like we have a solution in search of a problem, but what do I know, I just buy craigslist motors. |
turbo_jimi Member
Posted: Tue May 28, 2013 9:15 am Post subject: |
jchaussee wrote: | Heart diaease runs rampant in family. though if i have, ill know.more this werk, ill be youngest so far. or I just have been overly stressed and it caught up with me. Eother way my heart has always been bad |
I'm sure smoking doesn't help your situation either...
anyways, out of curiosity, wouldn't it be more cost effective and time efficient just to buy a 260hp or 290hp crate motor? That way, you take the guess work of trying to find out what is wrong with your current set up and you're not paying other people to fix and/or build your motor. _________________
MrMike98 Member
Posted: Tue May 28, 2013 11:41 am Post subject: |
AND jegs and summit are offering free shipping on any crate motor and no tax..................
i like this idea.. |
Posted: Tue May 28, 2013 12:21 pm Post subject: |
Not a bad option for a basic 350:
http://www.summitracing.com/parts/nal-12499529
Or he could just, you know, slap it all back together with new headgaskets for very little money since if I recall correctly it runs fine. I guess what I'm saying is the same as Aaron but kinder. Why spend the money? I understand its one thing if you have the extra money and want to have some fun learning how to build engines, but on the other hand why fix what ain't broke? _________________ 84 Camaro Z28 - LS1/T56
jchaussee Member
Posted: Tue May 28, 2013 1:10 pm Post subject: |
It looks as if it has alot of.miles since last rebuild. The top.of cylinders have a lip, may be just carbon bulid up. I figure if I look for deals and take time I should be in it around 1000. I figure if ibrebuild botton end stout then layer with some new heads and cam I should be able to het.some good power. I good heads for the price o a used nailgun. Cam if is usable was free be will probly need a regrind. Crank looks good. Was planning on repkacing oil pump. I just need to.figure out what pistons woukd work best for what I can afford and then but evertrhing seperate or in a kit. The reason I am.doing now is bevause I wont have time or money after fourth is born and this may be the lasy toy I get for decades. |
MrMike98 Member
Posted: Tue May 28, 2013 1:34 pm Post subject: |
OK IMHO if you tear it down then this is mandatory:
BLOCK-clean, mag(check for cracks), line bore for crank,deck, and bore next std size and hone,new cam bushings installed
rods-stress relieved and resized
crank-checked for streight and ground to next std. size.
heads-checked for cracks-valve job-surface decked for streightness reassemblied with new springs (match cam) and locks
new parts:
pistons rings & pins to match bore
oil pump
time chain
cam and lifters
all brearings and gaskets
AND pistons etc should be given to machine shop with block so they can match bore etc....
balance rotating assembly(highly recommended)
this was quick and I know i forgot a lot but these are the BASIC stuff IF you want a relaible smooth engine
just my .02 cents |
turbo_jimi Member
Posted: Tue May 28, 2013 2:56 pm Post subject: |
Won't is cost more money and time in the long run going with the rebuild? What if the the block or heads turn out to be bad? If you got money to buy all the parts and pay someone to do the work, you have the money to just buy the long block that has at least a 12 month warranty. Labor can get expensive. _________________
jchaussee Member
Posted: Tue May 28, 2013 3:14 pm Post subject: |
Ill know shape of heads in the morning. I suppose block could have issues. Thatll go in tje shop.early nrxt montj. Iwill have shop evaluate shape of pistins and rods and then see what thier opinion is. I am enjoying thr procexx si far.,and mike, thank you for list. Thats a goid start for me |
Posted: Tue May 28, 2013 3:54 pm Post subject: |
James brings up a good point. If you don't mind, could you let us know how much the work is costing you and where you are having it done? |
