		| Author | Message |
		| turbo_jimi Member
 1985  Chevrolet  Camaro Z/28
				|  Posted: Thu May 02, 2013 8:22 pm    Post subject: Edelbrock Fuel Pump 1721 |   |
				| Hi. John and I installed this last Saturday in the 85 because the stocker was leaking oil and about to explode. It has no return line. Do I need to vent this? Also, the throttle response seems better. Is that my imagination or can a fuel pump do this? Also, will I need to adjust my AFR on the carb due to the swap? It seems like it drives better but did notice the fuel odor was a little stronger than usual but nothing leaking. _________________
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Thu May 02, 2013 8:36 pm    Post subject: |   |
				| If the old pump wasn't keeping up then you might notice a difference. Shouldn't need to change anything. |  |
		| Back to top |  |
		| turbo_jimi Member
				|  Posted: Thu May 02, 2013 8:42 pm    Post subject: |   |
				| Cool! _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri May 03, 2013 5:28 am    Post subject: |   |
				| The return line was a vapor lock thing IIRC. I would cap that line well as it is submerged and could theoretically siphon if there were pressure in the tank.
 Do you have a normal functioning tank vent?
		| Back to top |  |
		| turbo_jimi Member
				|  Posted: Fri May 03, 2013 6:06 am    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  | The return line was a vapor lock thing IIRC. I would cap that line well as it is submerged and could theoretically siphon if there were pressure in the tank.
 I believe so.
		| Back to top |  |
		| jchaussee Member
				|  Posted: Fri May 03, 2013 1:49 pm    Post subject: |   |
				| What does normal tank vent entail? |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri May 03, 2013 8:42 pm    Post subject: |   |
				| 1/4" steel line from top of sending unit to charcoal can underhood. |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Sat May 04, 2013 12:08 am    Post subject: |   |
				| I do not have then. I have a rubber hose on end od that line under my hood that goes to inder car |  |
		| Back to top |  |
		| turbo_jimi Member
				|  Posted: Sat May 04, 2013 8:56 am    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  | 1/4" steel line from top of sending unit to charcoal can underhood. |
 I have the line but not the can.
		| Back to top |  |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Sat May 04, 2013 10:34 am    Post subject: |   |
				| Put a filter on the end of the line. _________________
		| Back to top |  |
		| turbo_jimi Member
				|  Posted: Sun May 05, 2013 4:25 pm    Post subject: |   |
				| Which line? _________________
		| Back to top |  |
				|  Posted: Sun May 05, 2013 6:17 pm    Post subject: |   |
				| The one that originally went into the charcoal canister.  _________________
		| Back to top |  |
