ET phone hoME Member
Posted: Mon Aug 08, 2005 12:29 pm Post subject: so wtf |
ok i just got my front brakes done new rotors and pads. after i broke them in they were just fine, but a couple weeks later one started to squeak. did i just f them up while i was breaking them in? do i have to get them turned again to get them to quiet down? _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
Camaro350Z28 Member
Posted: Mon Aug 08, 2005 5:09 pm Post subject: |
have you rechecked everything to make sure its all tight still? also did you go with cheap pads or rotors?.. either way get the rim off and inspect everything first. _________________ 1985 Z28. Don't know what im doing stupid 4th gen broke me.
Best 1/4 - 13.8 @ 101.98 60' 2.27 |
Posted: Mon Aug 08, 2005 10:48 pm Post subject: |
| Did you/they put the disc brake quiet goo on the pads /metal surfaces? |
alloy T56 Elitist
Posted: Tue Aug 09, 2005 9:15 am Post subject: |
| You also need to check the caliper mounting hardware. The slides need to be lubricated with high temp silicone grease, and not worn. Worn mounting hardware will cause vibration, which cause brake sqeel. Just watched a 1 hour video put out by Raybestos on this subject yesterday. Very imformative. |
Posted: Wed Aug 10, 2005 9:23 pm Post subject: |
hmm, i will have to look into this, thanks. _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
