Posted: Sun Mar 24, 2013 10:05 pm Post subject: Volvo stuff again |
So last time my Volvo 2.0L turbo was having misfire problems, I changed the spark plugs with some Denso Platinums and the problem went away and the car drove great - for about a week. It has been running like crap for a while now and today I changed the plugs again. This time I went with cheapo Autolite Iridiums. Again the car runs and drives like new, but for how long? I really don't wanna be changing the plugs every week. Two of the plugs I pulled looked fouled and the other two looked good. What would cause the plugs to foul so quickly? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
fiveoformula Member
Posted: Mon Mar 25, 2013 7:15 am Post subject: |
Are they fouled from oil? like wet or dry fouled? _________________
'88 FORMULA |
Posted: Mon Mar 25, 2013 8:40 am Post subject: |
Wet, seems like with fuel. |
Posted: Mon Mar 25, 2013 8:42 am Post subject: |
compression check? |
Posted: Mon Mar 25, 2013 8:44 am Post subject: |
And leakdown, if you can. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Mar 25, 2013 4:46 pm Post subject: |
How is the plug gap?
Are you sure you're putting turbo specific plugs in?
Anything can cause plugs to foul. Too strong a spark, weak spark, oil contamination, excess fuel, too cold a plug heat range, etc.
How many miles on this pig?
Fuel filter replaced ever?
I suspect maybe it's time to have the injectors cleaned. Doctor Injector does a great job and they are very reasonably priced. _________________ A redline a day keeps the carbon away! |
Posted: Mon Mar 25, 2013 4:53 pm Post subject: |
The car is fouling plugs because it is running in limp home mode.
That's what that light means on the dash.
I told you this two years ago when I last worked that car. |
Posted: Mon Mar 25, 2013 4:56 pm Post subject: |
aaron_sK wrote: | The car is fouling plugs because it is running in limp home mode.
Seriously? What's the check engine light code? What year is this? Come on NEWB we need more details.
Most ODB2 cars don't actually "LIMP HOME" unless it's a certain type of fault. _________________ A redline a day keeps the carbon away! |
Posted: Mon Mar 25, 2013 5:03 pm Post subject: |
Hell if I know. Last time I messed with this car was two years ago. Had SES light on, smelled and felt like it was running rich, and John was complaining of fouled plugs and poor economy.
I told him this was a no-brainer and he needed to pull codes and figure it out. Then, because John Stahlman, nothing happened for a very long time and now here we are. |
Posted: Mon Mar 25, 2013 5:11 pm Post subject: |
That's all John sees.
turbo_jimi Member
Posted: Mon Mar 25, 2013 5:19 pm Post subject: |
The code was for a mis-fire if I remember correctly. _________________
Posted: Mon Mar 25, 2013 6:22 pm Post subject: |
Twilightoptics wrote: |
That's all John sees. |
Absolutely factual!!! |
Posted: Mon Mar 25, 2013 8:16 pm Post subject: |
aaron_sK wrote: | Twilightoptics wrote: |
I wish I could deny it.
The SES was for an emissions sensor that i was never able to find. I reset that code long ago and it never came back. The only other codes were for misfires. I am gonna have to bite the bullet buy the expensive Volvo plugs. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Mar 28, 2013 1:54 pm Post subject: |
Moot point now. The Volvo is DEAD. |
Posted: Thu Mar 28, 2013 2:34 pm Post subject: |
What kind of dead? _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 28, 2013 8:48 pm Post subject: |
Que muerta? |
turbo_jimi Member
Posted: Thu Mar 28, 2013 9:14 pm Post subject: |
From his text, the oil light came on, he pulled over, checked the oil and it was full, so he continued on his way and the car started smoking and died. This happened in the middle of the 520 bridge.
Maybe the oil pump went bad? _________________
Posted: Thu Mar 28, 2013 11:04 pm Post subject: |
Nothing like breaking down in the middle of the 520 bridge during rush hour! |
Posted: Fri Mar 29, 2013 9:10 am Post subject: |
520 sucks
Guess you found the source of fouling. _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 04, 2013 4:44 pm Post subject: |
Sucks, but we all know the Swedish/Danish girls when mistreated by their fathers become self destructive.
actually no, that's not funny.... |
