		| Author | Message |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Tue Mar 12, 2013 8:12 pm    Post subject: |   |
				| Now that the alternator isn't making terrible noises I can hear the piston slap that my engine apparently has.   Oil pressure is fine and it goes away when it is up to temp, classic LS engine piston slap.
 http://youtu.be/Nzj-QMkDIQQ
		| Back to top |  |
				|  Posted: Tue Mar 12, 2013 8:23 pm    Post subject: |   |
				| Get some good oil in there and drive it. _________________
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Tue Mar 12, 2013 8:27 pm    Post subject: |   |
				| I have fresh Rotella T6 in it right now and a Wix filter.
 I will get the rest of what needs doing, done, and then drive the wheels off of it.
 Stupid dang heatercore replacement
 Interior reassembly
 Ball joint
 Alignment
 By the way Paul, you will be glad to know the y-pipe appears to be leak-free.
		| Back to top |  |
				|  Posted: Tue Mar 12, 2013 8:28 pm    Post subject: |   |
 I forgot about the slap issue myself till I read your post lol.
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Tue Mar 12, 2013 8:29 pm    Post subject: |   |
				| *Edit: ninja'd
 I'm with Paul. The T6 is about as good as your gonna do unless you want to go with a 15w40 and that seems like a bad idea for an LSx.
		| Back to top |  |
				|  Posted: Tue Mar 12, 2013 8:37 pm    Post subject: |   |
				| Tolerances aren't any tighter than a normal SBC, thick oil might do the trick. Maybe some Castrol 20w50 lol _________________
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Tue Mar 12, 2013 8:52 pm    Post subject: |   |
				| Honestly, as long as it goes away when warm I think I will stay with T6. I'm not too worried about it. Tons of people have some slap with these motors, mine isn't any different. I'm gonna see if my dad's '99 does it too when I go visit them this weekend.  He runs T6 too. Thank you GM.
 Loose motors make more power, right?
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Tue Mar 12, 2013 9:09 pm    Post subject: |   |
				| Only loose when they're cold.. |  |
		| Back to top |  |
				|  Posted: Tue Mar 12, 2013 9:16 pm    Post subject: |   |
				| That doesn't make sense at all. Blowby is wasted power. _________________
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Tue Mar 12, 2013 9:19 pm    Post subject: |   |
				| I know guys, I was trying to convey some sarcasm there.  I saw like 5 people in different threads on LS1Tech saying that if it has piston slap it will make more power.   Mine's not as bad as a lot of examples I found so I am just gonna go with it like I said before and not worry.
		| Back to top |  |
				|  Posted: Tue Mar 12, 2013 9:26 pm    Post subject: |   |
				| My jeep has nasty lifter tap every 10th time it starts up for a few seconds.
 Good oil makes it okay :O)
		| Back to top |  |
		| hnkajnk New Member
				|  Posted: Wed Mar 13, 2013 6:01 pm    Post subject: |   |
				| Yes, The Z28 has some "slap" when it's cold. I was kinda worried about it..  So this is normal? |  |
		| Back to top |  |
		| chevymad Master B
				|  Posted: Wed Mar 13, 2013 6:54 pm    Post subject: |   |
				| GM said if you didn't find too much iron on the magnetic drain plug then there was nothing to worry bout. Basically the pistons are loose when the engine is cold then expand to fill the cylinder.
 Did gm use forged pistons? Forgings were famous for this. Especially the old TRW ones because they started out oval and then rounded out as they warmed up.
		| Back to top |  |
		| fiveoformula Member
 1988  Pontiac  Formula
				|  Posted: Wed Mar 13, 2013 8:35 pm    Post subject: |   |
				| I always wondered what the rhyme or reason for the noise was... changing oil at chevy, I've heard enough of them start up, some ticked a little, some ticked a lot, some just turn over cold and don't make a sound. _________________
 '88 FORMULA
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Wed Mar 13, 2013 8:46 pm    Post subject: |   |
				| The LS1 pistons are not forged. They are hypereutectic aluminum.
 The short skirt piston design in the LS1 is more susceptible to piston slap than older Chevy engines. There's also talk that quality control wasn't too great on what size pistons that are "in spec" went into what bores that were also "in spec" but left enough clearance for the short skirt piston to knock around a little when it is cold. Basically, GM says it's normal as long as it goes away when the engine warms up.
 Tons of the GenIII engines rattle a bit when cold. No big deal.
		| Back to top |  |
		| 83Z28BlackBetty Bam-Ba-Lam
 1983  Chevrolet  Camaro Z/28
				|  Posted: Thu Mar 14, 2013 9:40 am    Post subject: |   |
				| Dude that's freaking Badass! I'm glad you got it all sorted out. I can't wait to see it in person. Good work man, that's something to be proud of for sure.
 -JAKE
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Fri Mar 15, 2013 10:28 am    Post subject: |   |
				| I drove around a bit last night. Runs good. Steam line is leaking a bit of coolant at the head crossover, I will fix that up soon so I can start driving it every day.
 This makes me want to do a swap in my truck too. The carb 350 just doesn't compare to the LS1!
		| Back to top |  |
		| fiveoformula Member
				|  Posted: Fri Mar 15, 2013 11:16 am    Post subject: |   |
				| Sick! Get a nice 5.3 or 6.0 in the truck too! |  |
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Fri Mar 15, 2013 11:59 am    Post subject: |   |
				| Yeah, I am thinking a 5.3/4L60E 2WD dropout would go in pretty easily and cheaply. I might not be able to resist the temptation.
		| Back to top |  |
		| Alphius Peanut
				|  Posted: Fri Mar 15, 2013 5:47 pm    Post subject: |   |
				| My new air filter. Airaid SynthaMax non-oiled filter. HotWheels for size comparison.
		| Back to top |  |
