ECM gremlins?
Goto page Previous  1, 2
BluFbdy
PostPosted: Wed Jan 02, 2013 11:28 pm    Post subject: Reply with quote
So i just ran the datalog a few mins ago, the knock counts on the graph look like a damn polygraph test. they go from 0 up to 244ish then reset, engine rpm is at 800, im assuming this means ive got the wrong damn knock sensor in there huh? i just fired it up and let it idle for the most part as its almost 11:30 i didnt wanna wake up my neighbors by giving it gas.
The knock line on the graph just spikes then drops and spikes and drops.....wrong sensor correct? This is one of the last hurdles i need to jump through minus the speedo issue but i dont wanna try to drive on icey roads and screw with my laptop, ill have to hook it up tomorrow after work before the sun goes completely down to rule out if my cluster is just toasted (god i hope so) since im not throwing a vss code as aarron pointed out.
Bashy Bashy soon enough itll all be fixed.
PostPosted: Thu Jan 03, 2013 6:51 am    Post subject: Reply with quote
Is there audible knock?
Did you torque the sensor to spec or just crank it in there?
What is the part number on the sensor?
PostPosted: Thu Jan 03, 2013 6:55 am    Post subject: Reply with quote
I'm with stupid
If its not audible snd you're sure timing isnt wayboff. Disabke thevflag for now.
You arent using the knock module right?
BluFbdy
PostPosted: Thu Jan 03, 2013 10:49 am    Post subject: Reply with quote
Scratch ny last post, the memcal is the issue. Rbob from dynamicefi pointed out the the maf memcals do not have the knock wax built into the chip and use it external to the ecm, whereas the SD has it on the memcal so its attempting to process info but it doesn't know how.
There's no audible knock of any kind, when you say disable the flag im seeing switch 24b error code masks (36-51) bit 4 - 43 which is the one I need to unchecked right?
Page 2 of 2
