Posted: Mon Nov 12, 2012 11:44 pm Post subject: |
So the moral of the story is that with enough weight reduction you will eventually compensate for a complete lack of torque?  |
Posted: Tue Nov 13, 2012 1:19 pm Post subject: |
| that mower looks like it could be a handful to control |
IROCDave Member
Posted: Tue Nov 20, 2012 5:04 am Post subject: |
I need my jimmy to do that  |
RK82 Member
Joined: 27 Jul 2008 Posts: 168 Location: vancouver B.C
1982 Pontiac Trans Am
Posted: Sun Jan 06, 2013 10:20 am Post subject: |
The most redneck part is driving around without a hood!  |
Posted: Sun Jan 06, 2013 11:20 am Post subject: |
| I always do that after I do alot of motor work incase it catchs on fire. |
Posted: Sun Jan 06, 2013 11:30 am Post subject: |
| You're proving my argument... |
Posted: Sun Jan 06, 2013 3:05 pm Post subject: |
It will get a hood after next weekend and I will snap a picture for you  |
IROCDave Member
Posted: Sun Jan 27, 2013 5:28 pm Post subject: |
1st vid is just crazy. The boat dropped a good 40'. The drives hit the sea floor and cracked the transom / hull. Not sure how the passengers faired, but a 40' drop is a 40' drop. Thats a 41' boat.
http://www.youtube.com/watch?v=M38GhA-2Quo
This vid shows how it's supposed to be done, notice he isnt close enough to shore fore the waves to be breaking?
https://www.youtube.com/watch?v=whQ3cl9UR2w |
Posted: Sun Feb 24, 2013 6:43 pm Post subject: |
| That looks quite similar to eastern oregon.. Why no 4lo? |
Posted: Mon Feb 25, 2013 5:19 am Post subject: |
| chevymad wrote: | | That looks quite similar to eastern oregon.. Why no 4lo? |
Not sure on the 4lo. Talked to a guy here at work, he thinks some stuff inside the tc is rusted up since it sat so long and had "milkshake" inside it. |
Posted: Mon Feb 25, 2013 6:23 am Post subject: |
Won't go into low or won't stay in low?
Trans in neutral? Truck able to roll freely? Also remember that the NP203's shift pattern is backwards from most other cases so if you're used to a normal truck and hop in one of those it can throw you off.
If the case is bad don't put too much into it, just start looking for a 205 or 208. The 203 is a ladies case to begin with.  |
